Audio problem VM/MOH
Discussion in '3CX Phone System - General' started by connexeon, Dec 22, 2011.
  1. connexeon
    May 20, 2010
    6
    Hi all,
    We are testing a new fanless system with SSD and Windows Embedded. 3CX installs perfectly and test calls between extensions work fine. Voicemail or music on hold (probably any playback of recorded stuff) sounds very stuttering. The performance of the system (CPU and memory usage) look fine, also network performance should not be an issue.
    Any idea on what causes this? Thank you.
    Regards,
    Hannes
    10,060
    201
    Other than an SSD, you don't say what hardware (CPU, Memory), your system consists of.
  3. connexeon
    May 20, 2010
    6
    Hi!
    These are the specs of the system:
    Mainboard Intel D945GSEJT Johnstown Mini-ITX (1.6 GHz Atom processor)
    2GB memory Transcend SO-DIMM DDR2 800
    40GB SSD Intel 320 Series SATA
    Microsoft Windows Embedded Standard 2009
  4. leejor
    10,060
    201
    I've put together several systems using versions of Intel Mini ITX along with 2 Gb of memory, with no issues, running 3CX. I can't see why a SSD would introduce any problems as it is much faster than a mechanical drive. I was thinking about replacing one of my drives with a SSD once the prices come down a bit. I'm in the process of installing one on a laptop using Windows 7. I have heard that Win XP, and other earlier operating systems, can not take full advantage of the speed offered by a solid state drive, and that might be the problem
    There may be a setting in the BIOS that is causing some sort of a read/buffer issue. Do a search for your MB model and using SSD's. If you've gone over everything else, try cloning the SSD onto a regular hard drive, and run that. If the problem is gone, then you know that it is the SSD and an incompatibility on your system (motherboard), or, with the settings in Windows, that is causing the problems.
  5. connexeon
    May 20, 2010
    6
    Thanks for your suggestions. We ran some benchmarks on the SSD and it looks like there's a poor read performance. This is probably the cause of the problem. This SSD should perform much better I think, so we're looking into a problem with the drivers/bios settings.
  6. leejor
    10,060
    201
    I'd be very interested in hearing what you find, as, I too want to eventually switch over to SSD's in the next few years as the cost justifies the switch.
  7. Patrice
    Dec 29, 2011
    Check that your hard drive is configured for optimized performance :
    - Open the device manager
    - Under Disk Drives, open the properties for your disk
    - In the "Policies" tab, tick "Optimize for performance" and "Enable write caching on disk"
    - Click on Ok
    - Under "IDE/ATA/ATAPI", open the properties for the all channels
    - Enable DMA Transfer in the Advanced Settings Tab
    You should also check that you are using the good drivers for your chipset. (check intel support site)
    You can also disable NTFS last access update, which can be very time consuming on slow computers.
    You can find this registry tweak under :
    HKLM\SYSTEM\CurrentControlSet\Control\FileSystem
    set NtfsDisableLastAccessUpdate (DWord) to 1 to disable
    then reboot.
    (source : http://technet.microsoft.com/en-us/library/cc959914.aspx )
    At last, check that disk power management is disabled in bios and windows power management.
    As leejor said, windows xp is not recommended for ssd drives because it does not support the TRIM command.
    Regards,
    Patrice
  8. connexeon
    May 20, 2010
    6
    Thanks for your input. I've checked your suggestions and all these settings are already set this way. I also checked the Intel site for updated drivers, but we are already using the latest. We're looking into AHCI / PCI IDE mode now.
  9. complex1
    complex1 Active Member
    Jan 25, 2010
    728
    31
    Maybe this little app can help you? It tweaks Windows 2K/XP/Vista and 7 for you.
    There is a free and a paid (Pro) edition
    http://elpamsoft.com/Downloads.aspx?Name=SSD%20Tweaker
    Good luck.
  10. connexeon
    May 20, 2010
    6
    Thanks for your suggestion.
    We already tried SSD Tweaker to tune some settings but we did not gain (enough) performance unfortunately.
  11. complex1
    Jan 25, 2010
    728
    31
    I have done some searching on Dutch benchmark sites for the Intel SSDSA2CT040G3 and I think the best you can do is change the SSD for, or another and faster one, or replace it for an old fashion hard drive.
    So what leejor earlier mentioned “If you've gone over everything else, try cloning the SSD onto a regular hard drive, and run that.” I will if I was you do that first before going further.
    Good luck.
