Audio Problem
Discussion in '3CX Phone System - General' started by fantasma, May 25, 2007.
  1. fantasma
    May 25, 2007
    Hi all, today my system stop working. When I call from an external or internal line I don't receive audio (IVR or anything). If I call direct the extension, extensio rings normally, but when I hangup, nothing.
    I don't know if it's important the correct configuration in audio card, because I have some controller conflict inside with it, anyway here is my log, if you can help me:
    17:19:57.869 CallLegImpl::eek:nConnected Call(C:7): Created audio channel for Ext.101 (192.168.1.149:10082) with Media Server (192.168.1.117:7012)
    17:19:57.829 CallConf::eek:nIncoming Call(C:7): Incoming call from Ext.101 to sip:999@192.168.1.117
    16:58:46.831 MediaServerReporting::RTPReceiver from 'target-e0de6ea4:0/MediaServer':No RTP packets were received on 0000000A@:remoteAddr=12.47.46.157:11226,extAddr=190.45.57.32:9000,localAddr=0.0.0.0:9000
    16:58:46.801 StratInOut::eek:nHangUp Call(C:6): Call from Ln:10000@IParea to 101 has been terminated
    16:58:39.841 CallConf::eek:nProvisional Call(C:6): got response from 101
    16:57:56.359 CallLegImpl::eek:nConnected Call(C:6): Created audio channel for Ln:10000@IParea (12.47.46.157:11226) with Media Server (190.45.57.32:9000)
    16:57:56.319 CallConf::eek:nIncoming Call(C:6): Incoming call from Ln:10000@IParea to sip:7000000@190.45.57.32:5060
    16:55:22.838 ListenConnect SL: connected target-e0de6ea4:0/PHPExtension_0 at [target-e0de6ea4:0]/PHPExtension_0
    16:54:59.344 MediaServerReporting::RTPReceiver from 'target-e0de6ea4:0/MediaServer':No RTP packets were received on 00000008@:remoteAddr=12.47.46.157:16716,extAddr=190.45.57.32:9002,localAddr=0.0.0.0:9002
    16:54:59.204 StratInOut::eek:nHangUp Call(C:5): Call from Ln:10000@IParea to 101 has been terminated
    16:54:55.929 CallConf::eek:nProvisional Call(C:5): got response from 101
    16:54:12.147 CallLegImpl::eek:nConnected Call(C:5): Created audio channel for Ln:10000@IParea (12.47.46.157:16716) with Media Server (190.45.57.32:9002)
    16:54:12.106 CallConf::eek:nIncoming Call(C:5): Incoming call from Ln:10000@IParea to sip:7000000@190.45.57.32:5060
    16:49:42.969 MediaServerReporting::RTPReceiver from 'target-e0de6ea4:0/MediaServer':No RTP packets were received on 00000006@:remoteAddr=12.47.46.157:19492,extAddr=190.45.57.32:9000,localAddr=0.0.0.0:9000
    16:49:42.959 StratLink::eek:nHangUp Call(C:4): Ext.101 hung up call; reason: BYE
    16:49:39.034 CallLegImpl::eek:nConnected Call(C:4): Created audio channel for Ext.101 (192.168.1.149:10076) with Media Server (192.168.1.117:7006)
    Thanks,
    Sebastian
