audio problem
Discussion in '3CX Phone System - General' started by callnetcenter, Aug 15, 2007.
  1. callnetcenter
    Aug 15, 2007
    I read somewhere, if I don't use the same codec in phone and in softere pbx the voice will be delayed, this seems to be happen with my 3cx. The voice is intrerupt and delayed. I' don't know why!?
    The conection of the internet is 2.5 Mb/s. I read the configure manul of 3cx phone system and the configure in the management console it's ok.
    But the problem with the voice is alwais the same.
    In codec voice I have added all codecs, my voip provider suports this codecs:
    G.711 (64 kbps)
    G.726 (32 kbps)
    G.729 (8 kbps)
    G.723 (5.3 & 6.3 kbps)
    iLBC (20ms & 30ms)
    and my voip phone Grandstream Budge Tone-100
    PCMU
    PCMA
    G729
    G723
    G726-32
    G722(wideband)
    iLBC
    please tell me how can I choose the codecs on the 3cx system and voip phone to resolve this problem
  2. Anonymous
    Anonymous Guest
    Please do not post same post under different headings.
    It is a waste of time, not only mine but others aswell. Stick to one post for one problem......... and before I forget.
    USE SEARCH
