Audio Problem
Discussion in '3CX Phone System - General' started by marcovalli, Feb 27, 2007.
  1. marcovalli
    Feb 26, 2007
    14
    Hallo, i'have a little problem.. I cant' hear the vocal mail. I don't hear also the welcome message.... so... i dont' hear nothing !! Can you help me ??
    It's a codec problem ?? I use G711u
    Thank
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Is this a fresh install or upgrade ?
    Is the VoiceMail service running?
    Are you conencting the 999 number?
    What logs are showing up in the server status log page ?
  3. marcovalli
    Feb 26, 2007
    14
    - It'a a fresh install
    - The Voicemail service it's ok
    - When I call 999 i see on the screen the monitor status connected (999)
    -2007/02/28 >>
    17:30:45.816|Service.cpp(204)|Log2||??: *** Initialize ***
    17:30:45.816|Service.cpp(235)|Log2||??: Local port range is set to:7000-7499
    17:30:45.816|Service.cpp(249)|Log2||??: External port range is set to:9000-9003
    17:30:45.906|Service.cpp(289)|Log2||??: *** Start Server ***
    17:30:45.916|Service.cpp(48)|Log2||??: *** Listen ***
    17:30:45.916|Service.cpp(65)|Log2||??: *** Connecting to [127.0.0.1:5482] ***
    17:30:49.942|Service.cpp(76)|Log2||??: CM not found on 127.0.0.1:5482
    17:30:49.942|Service.cpp(90)|Log2||??: *** Connecting to [127.0.0.1:5483] ***
    17:30:50.943|Service.cpp(95)|Log2||??: *** Connected to nb-muletto:5483/IVRServer at 127.0.0.1:5483 ***
    17:30:51.945|Service.cpp(65)|Log2||??: *** Connecting to [127.0.0.1:5482] ***
    17:30:53.948|Service.cpp(70)|Log2||??: *** Connected to nb-muletto:5482/CallManager at 127.0.0.1:5482 ***
    18:25:22.067|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=00000001@127.0.0.1; rtp=7000
    18:25:22.067|MediaServer.cpp(574)|Log2||??: EndPoint 00000001@127.0.0.1 joined to call 00000000
    18:25:22.087|MediaServer.cpp(583)|Log2||??: starting send on new call 00000000
    18:25:34.475|MSEndPoint.cpp(374)|Error1||??: Possible firewall problem. Address mapping failed on STUN server 194.221.62.209:3478 for local address "127.0.0.1:9000"
    18:25:34.495|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=00000002@127.0.0.1; rtp=9000
    18:25:34.495|MediaServer.cpp(574)|Log2||??: EndPoint 00000002@127.0.0.1 joined to call 00000000
    18:25:34.515|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=00000001@127.0.0.1(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7000
    RTCP:127.0.0.1:7001
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:10.0.0.33:10000
    Party RTCP:10.0.0.33:10001
    Decoders:
    0:pCMU
    8:pCMA
    -1:telephony-event
    18:25:34.515|MediaServer.cpp(322)|Log2||??: EndPoint 00000001@127.0.0.1 resumed
    18:25:34.515|MediaServer.cpp(322)|Log2||??: EndPoint 00000002@127.0.0.1 resumed
    18:25:34.825|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=00000002@127.0.0.1(EXTERNAL)
    Status: MSEP_EXTERNAL
    RTP:127.0.0.1:9000
    RTCP:127.0.0.1:9001
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:80.239.235.164:57558
    Party RTCP:80.239.235.164:57559
    Decoders:
    0:pCMU
    -1:telephony-event
    18:25:40.333|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    RTP:127.0.0.1:9000
    RTCP:127.0.0.1:9001
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Decoders:
    0:pCMU
    -1:telephony-event
    18:25:40.333|MediaServer.cpp(322)|Log2||??: EndPoint 00000001@127.0.0.1 resumed
    18:25:40.343|MediaServer.cpp(322)|Log2||??: EndPoint 00000002@127.0.0.1 resumed
    18:26:12.650|MediaServer.cpp(656)|Log2||??: EndPoint 00000001@127.0.0.1 removed from call 00000000
    18:26:12.650|MediaServer.cpp(656)|Log2||??: EndPoint 00000002@127.0.0.1 removed from call 00000000
    18:26:12.650|MediaServer.cpp(623)|Error1||??: EndPoint 00000001@127.0.0.1not found in call 00000000
    18:26:12.680|MediaServer.cpp(386)|Log2||??: references to EndPoint 00000001@127.0.0.1 were removed
    18:26:12.690|MediaServer.cpp(623)|Error1||??: EndPoint 00000002@127.0.0.1not found in call 00000000
    18:26:12.700|MediaServer.cpp(386)|Log2||??: references to EndPoint 00000002@127.0.0.1 were removed
    18:26:12.700|MediaServer.cpp(684)|Log2||??: references to call 00000000 were removed
    18:26:12.700|MSCallConf.cpp(30)|Log2||??: Call: 00000000 destroyed
    18:27:04.194|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=00000003@127.0.0.1; rtp=7002
    18:27:04.194|MediaServer.cpp(574)|Log2||??: EndPoint 00000003@127.0.0.1 joined to call 00000001
    18:27:04.194|MediaServer.cpp(583)|Log2||??: starting send on new call 00000001
    18:27:04.244|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=00000004@127.0.0.1; rtp=7004
    18:27:04.244|MediaServer.cpp(574)|Log2||??: EndPoint 00000004@127.0.0.1 joined to call 00000001
    18:27:04.244|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=00000003@127.0.0.1(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7002
    RTCP:127.0.0.1:7003
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:10.0.0.31:10002
    Party RTCP:10.0.0.31:10003
    Decoders:
    0:pCMU
    8:pCMA
    -1:telephony-event
    18:27:08.069|MediaServer.cpp(619)|Log2||??: EndPoint 00000003@127.0.0.1 removed from call 00000001
    18:27:08.110|MediaServer.cpp(386)|Log2||??: references to EndPoint 00000003@127.0.0.1 were removed
    18:27:08.120|MediaServer.cpp(656)|Log2||??: EndPoint 00000004@127.0.0.1 removed from call 00000001
    18:27:08.120|MediaServer.cpp(623)|Error1||??: EndPoint 00000004@127.0.0.1not found in call 00000001
    18:27:08.130|MediaServer.cpp(386)|Log2||??: references to EndPoint 00000004@127.0.0.1 were removed
    18:27:08.130|MediaServer.cpp(684)|Log2||??: references to call 00000001 were removed
    18:27:08.130|MSCallConf.cpp(30)|Log2||??: Call: 00000001 destroyed
    18:28:34.594|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=00000005@127.0.0.1; rtp=7006
    18:28:34.594|MediaServer.cpp(574)|Log2||??: EndPoint 00000005@127.0.0.1 joined to call 00000002
    18:28:34.594|MediaServer.cpp(583)|Log2||??: starting send on new call 00000002
    18:28:40.743|MSEndPoint.cpp(374)|Error1||??: Possible firewall problem. Address mapping failed on STUN server 194.221.62.209:3478 for local address "127.0.0.1:9002"
    18:28:40.763|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=00000006@127.0.0.1; rtp=9002
    18:28:40.763|MediaServer.cpp(574)|Log2||??: EndPoint 00000006@127.0.0.1 joined to call 00000002
    18:28:40.763|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=00000005@127.0.0.1(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7006
    RTCP:127.0.0.1:7007
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:10.0.0.33:10006
    Party RTCP:10.0.0.33:10007
    Decoders:
    0:pCMU
    8:pCMA
    -1:telephony-event
    18:28:40.763|MediaServer.cpp(322)|Log2||??: EndPoint 00000005@127.0.0.1 resumed
    18:28:40.763|MediaServer.cpp(322)|Log2||??: EndPoint 00000006@127.0.0.1 resumed
    18:28:40.933|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=00000006@127.0.0.1(EXTERNAL)
    RTP:127.0.0.1:9002
    RTCP:127.0.0.1:9003
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:80.239.235.169:8444
    Party RTCP:80.239.235.169:8445
    Decoders:
    0:pCMU
    -1:telephony-event
    18:28:45.490|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=00000007@127.0.0.1; rtp=7008
    18:28:45.490|MediaServer.cpp(574)|Log2||??: EndPoint 00000007@127.0.0.1 joined to call 00000003
    18:28:45.490|MediaServer.cpp(583)|Log2||??: starting send on new call 00000003
    18:28:45.570|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=00000008@127.0.0.1; rtp=7010
    18:28:45.570|MediaServer.cpp(574)|Log2||??: EndPoint 00000008@127.0.0.1 joined to call 00000003
    18:28:45.570|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=00000007@127.0.0.1(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7008
    RTCP:127.0.0.1:7009
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    3:GSM
    98:telephony-event
    Party RTP:212.97.59.80:57340
    Party RTCP:212.97.59.80:57341
    Decoders:
    0:pCMU
    3:GSM
    8:pCMA
    101:telephony-event
    18:28:45.570|MediaServer.cpp(322)|Log2||??: EndPoint 00000007@127.0.0.1 resumed
    18:28:45.570|MediaServer.cpp(322)|Log2||??: EndPoint 00000008@127.0.0.1 resumed
    18:28:50.206|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=00000008@127.0.0.1(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7010
    RTCP:127.0.0.1:7011
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:10.0.0.31:10004
    Party RTCP:10.0.0.31:10005
    Decoders:
    0:pCMU
    -1:telephony-event
    18:28:50.206|MediaServer.cpp(322)|Log2||??: EndPoint 00000007@127.0.0.1 resumed
    18:28:50.216|MediaServer.cpp(322)|Log2||??: EndPoint 00000008@127.0.0.1 resumed
    18:28:51.038|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    RTP:127.0.0.1:9002
    RTCP:127.0.0.1:9003
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Decoders:
    0:pCMU
    -1:telephony-event
    18:28:51.038|MediaServer.cpp(322)|Log2||??: EndPoint 00000005@127.0.0.1 resumed
    18:28:51.048|MediaServer.cpp(322)|Log2||??: EndPoint 00000006@127.0.0.1 resumed
    18:29:23.274|MediaServer.cpp(656)|Log2||??: EndPoint 00000005@127.0.0.1 removed from call 00000002
    18:29:23.274|MediaServer.cpp(656)|Log2||??: EndPoint 00000006@127.0.0.1 removed from call 00000002
    18:29:23.274|MediaServer.cpp(623)|Error1||??: EndPoint 00000005@127.0.0.1not found in call 00000002
    18:29:23.314|MediaServer.cpp(386)|Log2||??: references to EndPoint 00000005@127.0.0.1 were removed
    18:29:23.354|MediaServer.cpp(623)|Error1||??: EndPoint 00000006@127.0.0.1not found in call 00000002
    18:29:23.394|MediaServer.cpp(386)|Log2||??: references to EndPoint 00000006@127.0.0.1 were removed
    18:29:23.414|MediaServer.cpp(684)|Log2||??: references to call 00000002 were removed
    18:29:23.414|MSCallConf.cpp(30)|Log2||??: Call: 00000002 destroyed
    18:29:23.845|MediaServer.cpp(656)|Log2||??: EndPoint 00000007@127.0.0.1 removed from call 00000003
    18:29:23.845|MediaServer.cpp(656)|Log2||??: EndPoint 00000008@127.0.0.1 removed from call 00000003
    18:29:23.845|MediaServer.cpp(623)|Error1||??: EndPoint 00000007@127.0.0.1not found in call 00000003
    18:29:23.875|MediaServer.cpp(386)|Log2||??: references to EndPoint 00000007@127.0.0.1 were removed
    18:29:23.875|MediaServer.cpp(623)|Error1||??: EndPoint 00000008@127.0.0.1not found in call 00000003
    18:29:23.895|MediaServer.cpp(386)|Log2||??: references to EndPoint 00000008@127.0.0.1 were removed
    18:29:23.895|MediaServer.cpp(684)|Log2||??: references to call 00000003 were removed
    18:29:23.895|MSCallConf.cpp(30)|Log2||??: Call: 00000003 destroyed
    18:29:48.901|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=00000009@127.0.0.1; rtp=7012
    18:29:48.901|MediaServer.cpp(574)|Log2||??: EndPoint 00000009@127.0.0.1 joined to call 00000004
    18:29:48.901|MediaServer.cpp(583)|Log2||??: starting send on new call 00000004
    18:29:59.115|MSEndPoint.cpp(374)|Error1||??: Possible firewall problem. Address mapping failed on STUN server 80.239.235.209:3478 for local address "127.0.0.1:9000"
    18:29:59.135|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=0000000A@127.0.0.1; rtp=9000
    18:29:59.135|MediaServer.cpp(574)|Log2||??: EndPoint 0000000A@127.0.0.1 joined to call 00000004
    18:29:59.135|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=00000009@127.0.0.1(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7012
    RTCP:127.0.0.1:7013
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Decoders:
    0:pCMU
    8:pCMA
    -1:telephony-event
    18:29:59.135|MediaServer.cpp(322)|Log2||??: EndPoint 00000009@127.0.0.1 resumed
    18:29:59.135|MediaServer.cpp(322)|Log2||??: EndPoint 0000000A@127.0.0.1 resumed
    18:29:59.306|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=0000000A@127.0.0.1(EXTERNAL)
    RTP:127.0.0.1:9000
    RTCP:127.0.0.1:9001
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:80.239.235.180:41146
    Party RTCP:80.239.235.180:41147
    Decoders:
    0:pCMU
    -1:telephony-event
    18:30:03.572|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=0000000B@127.0.0.1; rtp=7014
    18:30:03.572|MediaServer.cpp(574)|Log2||??: EndPoint 0000000B@127.0.0.1 joined to call 00000005
    18:30:03.572|MediaServer.cpp(583)|Log2||??: starting send on new call 00000005
    18:30:03.612|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=0000000C@127.0.0.1; rtp=7016
    18:30:03.612|MediaServer.cpp(574)|Log2||??: EndPoint 0000000C@127.0.0.1 joined to call 00000005
    18:30:03.612|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=0000000B@127.0.0.1(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7014
    RTCP:127.0.0.1:7015
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    3:GSM
    98:telephony-event
    Party RTP:212.97.59.80:57692
    Party RTCP:212.97.59.80:57693
    Decoders:
    0:pCMU
    3:GSM
    8:pCMA
    101:telephony-event
    18:30:03.612|MediaServer.cpp(322)|Log2||??: EndPoint 0000000B@127.0.0.1 resumed
    18:30:03.612|MediaServer.cpp(322)|Log2||??: EndPoint 0000000C@127.0.0.1 resumed
    18:30:09.560|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=0000000C@127.0.0.1(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7016
    RTCP:127.0.0.1:7017
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:10.0.0.31:10006
    Party RTCP:10.0.0.31:10007
    Decoders:
    0:pCMU
    -1:telephony-event
    18:30:09.560|MediaServer.cpp(322)|Log2||??: EndPoint 0000000B@127.0.0.1 resumed
    18:30:09.560|MediaServer.cpp(322)|Log2||??: EndPoint 0000000C@127.0.0.1 resumed
    18:30:10.261|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    RTP:127.0.0.1:9000
    RTCP:127.0.0.1:9001
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Decoders:
    0:pCMU
    -1:telephony-event
    18:30:10.261|MediaServer.cpp(322)|Log2||??: EndPoint 00000009@127.0.0.1 resumed
    18:30:10.271|MediaServer.cpp(322)|Log2||??: EndPoint 0000000A@127.0.0.1 resumed
    18:30:42.378|MediaServer.cpp(656)|Log2||??: EndPoint 00000009@127.0.0.1 removed from call 00000004
    18:30:42.378|MediaServer.cpp(656)|Log2||??: EndPoint 0000000A@127.0.0.1 removed from call 00000004
    18:30:42.378|MediaServer.cpp(623)|Error1||??: EndPoint 00000009@127.0.0.1not found in call 00000004
    18:30:42.428|MediaServer.cpp(386)|Log2||??: references to EndPoint 00000009@127.0.0.1 were removed
    18:30:42.468|MediaServer.cpp(623)|Error1||??: EndPoint 0000000A@127.0.0.1not found in call 00000004
    18:30:42.528|MediaServer.cpp(386)|Log2||??: references to EndPoint 0000000A@127.0.0.1 were removed
    18:30:42.548|MediaServer.cpp(684)|Log2||??: references to call 00000004 were removed
    18:30:42.548|MSCallConf.cpp(30)|Log2||??: Call: 00000004 destroyed
    18:30:42.888|MediaServer.cpp(656)|Log2||??: EndPoint 0000000B@127.0.0.1 removed from call 00000005
    18:30:42.888|MediaServer.cpp(656)|Log2||??: EndPoint 0000000C@127.0.0.1 removed from call 00000005
    18:30:42.888|MediaServer.cpp(623)|Error1||??: EndPoint 0000000B@127.0.0.1not found in call 00000005
    18:30:42.908|MediaServer.cpp(386)|Log2||??: references to EndPoint 0000000B@127.0.0.1 were removed
    18:30:42.908|MediaServer.cpp(623)|Error1||??: EndPoint 0000000C@127.0.0.1not found in call 00000005
    18:30:42.928|MediaServer.cpp(386)|Log2||??: references to EndPoint 0000000C@127.0.0.1 were removed
    18:30:42.928|MediaServer.cpp(684)|Log2||??: references to call 00000005 were removed
    18:30:42.938|MSCallConf.cpp(30)|Log2||??: Call: 00000005 destroyed
    18:31:40.091|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=0000000D@127.0.0.1; rtp=7018
    18:31:40.091|MediaServer.cpp(574)|Log2||??: EndPoint 0000000D@127.0.0.1 joined to call 00000006
    18:31:40.091|MediaServer.cpp(583)|Log2||??: starting send on new call 00000006
    18:31:46.249|MSEndPoint.cpp(374)|Error1||??: Possible firewall problem. Address mapping failed on STUN server 80.239.235.209:3478 for local address "127.0.0.1:9002"
    18:31:46.270|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=0000000E@127.0.0.1; rtp=9002
    18:31:46.270|MediaServer.cpp(574)|Log2||??: EndPoint 0000000E@127.0.0.1 joined to call 00000006
    18:31:46.270|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=0000000D@127.0.0.1(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7018
    RTCP:127.0.0.1:7019
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:10.0.0.33:10002
    Party RTCP:10.0.0.33:10003
    Decoders:
    0:pCMU
    8:pCMA
    -1:telephony-event
    18:31:46.270|MediaServer.cpp(322)|Log2||??: EndPoint 0000000D@127.0.0.1 resumed
    18:31:46.270|MediaServer.cpp(322)|Log2||??: EndPoint 0000000E@127.0.0.1 resumed
    18:31:46.500|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=0000000E@127.0.0.1(EXTERNAL)
    RTP:127.0.0.1:9002
    RTCP:127.0.0.1:9003
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:194.221.62.171:57724
    Party RTCP:194.221.62.171:57725
    Decoders:
    0:pCMU
    -1:telephony-event
    18:32:25.015|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    RTP:127.0.0.1:9002
    RTCP:127.0.0.1:9003
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Decoders:
    0:pCMU
    -1:telephony-event
    18:32:25.015|MediaServer.cpp(322)|Log2||??: EndPoint 0000000D@127.0.0.1 resumed
    18:32:25.015|MediaServer.cpp(322)|Log2||??: EndPoint 0000000E@127.0.0.1 resumed
    18:32:57.272|MediaServer.cpp(656)|Log2||??: EndPoint 0000000D@127.0.0.1 removed from call 00000006
    18:32:57.272|MediaServer.cpp(656)|Log2||??: EndPoint 0000000E@127.0.0.1 removed from call 00000006
    18:32:57.272|MediaServer.cpp(623)|Error1||??: EndPoint 0000000D@127.0.0.1not found in call 00000006
    18:32:57.302|MediaServer.cpp(386)|Log2||??: references to EndPoint 0000000D@127.0.0.1 were removed
    18:32:57.302|MediaServer.cpp(623)|Error1||??: EndPoint 0000000E@127.0.0.1not found in call 00000006
    18:32:57.322|MediaServer.cpp(386)|Log2||??: references to EndPoint 0000000E@127.0.0.1 were removed
    18:32:57.322|MediaServer.cpp(684)|Log2||??: references to call 00000006 were removed
    18:32:57.322|MSCallConf.cpp(30)|Log2||??: Call: 00000006 destroyed
    18:33:24.320|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=0000000F@127.0.0.1; rtp=7020
    18:33:24.320|MediaServer.cpp(574)|Log2||??: EndPoint 0000000F@127.0.0.1 joined to call 00000007
    18:33:24.320|MediaServer.cpp(583)|Log2||??: starting send on new call 00000007
    18:33:30.479|MSEndPoint.cpp(374)|Error1||??: Possible firewall problem. Address mapping failed on STUN server 80.239.235.209:3478 for local address "127.0.0.1:9000"
    18:33:30.489|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=00000010@127.0.0.1; rtp=9000
    18:33:30.489|MediaServer.cpp(574)|Log2||??: EndPoint 00000010@127.0.0.1 joined to call 00000007
    18:33:30.489|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=0000000F@127.0.0.1(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7020
    RTCP:127.0.0.1:7021
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:10.0.0.31:10000
    Party RTCP:10.0.0.31:10001
    Decoders:
    0:pCMU
    8:pCMA
    -1:telephony-event
    18:33:30.489|MediaServer.cpp(322)|Log2||??: EndPoint 0000000F@127.0.0.1 resumed
    18:33:30.489|MediaServer.cpp(322)|Log2||??: EndPoint 00000010@127.0.0.1 resumed
    18:33:31.050|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=00000010@127.0.0.1(EXTERNAL)
    RTP:127.0.0.1:9000
    RTCP:127.0.0.1:9001
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Party RTP:194.120.0.173:24956
    Party RTCP:194.120.0.173:24957
    Decoders:
    0:pCMU
    -1:telephony-event
    18:33:52.421|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    RTP:127.0.0.1:9000
    RTCP:127.0.0.1:9001
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Decoders:
    0:pCMU
    -1:telephony-event
    18:33:52.431|MediaServer.cpp(322)|Log2||??: EndPoint 0000000F@127.0.0.1 resumed
    18:33:52.431|MediaServer.cpp(322)|Log2||??: EndPoint 00000010@127.0.0.1 resumed
    18:34:24.487|MediaServer.cpp(656)|Log2||??: EndPoint 0000000F@127.0.0.1 removed from call 00000007
    18:34:24.487|MediaServer.cpp(656)|Log2||??: EndPoint 00000010@127.0.0.1 removed from call 00000007
    18:34:24.487|MediaServer.cpp(623)|Error1||??: EndPoint 0000000F@127.0.0.1not found in call 00000007
    18:34:24.517|MediaServer.cpp(386)|Log2||??: references to EndPoint 0000000F@127.0.0.1 were removed
    18:34:24.517|MediaServer.cpp(623)|Error1||??: EndPoint 00000010@127.0.0.1not found in call 00000007
    18:34:24.537|MediaServer.cpp(386)|Log2||??: references to EndPoint 00000010@127.0.0.1 were removed
    18:34:24.537|MediaServer.cpp(684)|Log2||??: references to call 00000007 were removed
    18:34:24.537|MSCallConf.cpp(30)|Log2||??: Call: 00000007 destroyed
    18:48:55.429|MediaServer.cpp(116)|Log2||??: EndPoint created successfuly: ID=00000011@127.0.0.1; rtp=7022
    18:48:55.429|MediaServer.cpp(574)|Log2||??: EndPoint 00000011@127.0.0.1 joined to call 00000008
    18:48:55.429|MediaServer.cpp(583)|Log2||??: starting send on new call 00000008
    18:48:55.449|MediaServer.cpp(267)|Log2||??: Party changed sucessfuly on Endpoint:
    EndPoint: ID=00000011@127.0.0.1(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7022
    RTCP:127.0.0.1:7023
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Decoders:
    0:pCMU
    8:pCMA
    -1:telephony-event
    18:48:55.449|MediaServer.cpp(322)|Log2||??: EndPoint 00000011@127.0.0.1 resumed
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7022
    RTCP:127.0.0.1:7023
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    0:pCMU
    98:telephony-event
    Decoders:
    0:pCMU
    8:pCMA
    -1:telephony-event
    18:48:55.489|MediaServer.cpp(322)|Log2||??: EndPoint 00000011@127.0.0.1 resumed
    18:48:56.671|MediaServer.cpp(447)|Log2||??: EndPoint00000011@127.0.0.1 play file C:\WINDOWS\TEMP\prmpt6a1eab.wav
    18:48:57.552|MSCallConf.cpp(202)|Log2||??: Played File on 00000011@127.0.0.1 closed
    18:48:57.552|MediaServer.cpp(413)|Log2||??: PlayFile on 00000011@127.0.0.1 stopped
    18:48:57.562|MediaServer.cpp(447)|Log2||??: EndPoint00000011@127.0.0.1 play file C:\WINDOWS\TEMP\prmptc604b1.wav
    18:48:58.814|MSCallConf.cpp(202)|Log2||??: Played File on 00000011@127.0.0.1 closed
    18:48:58.814|MediaServer.cpp(413)|Log2||??: PlayFile on 00000011@127.0.0.1 stopped
    18:48:58.814|MediaServer.cpp(322)|Log2||??: EndPoint 00000011@127.0.0.1 resumed
    18:49:08.899|MediaServer.cpp(413)|Log2||??: PlayFile on 00000011@127.0.0.1 stopped
    18:49:08.899|MediaServer.cpp(322)|Log2||??: EndPoint 00000011@127.0.0.1 resumed
    18:49:08.909|MediaServer.cpp(447)|Log2||??: EndPoint00000011@127.0.0.1 play file C:\WINDOWS\TEMP\prmpt6aed58.wav
    18:49:10.131|MSCallConf.cpp(202)|Log2||??: Played File on 00000011@127.0.0.1 closed
    18:49:10.131|MediaServer.cpp(413)|Log2||??: PlayFile on 00000011@127.0.0.1 stopped
    18:49:10.131|MediaServer.cpp(619)|Log2||??: EndPoint 00000011@127.0.0.1 removed from call 00000008
    18:49:10.131|MediaServer.cpp(322)|Log2||??: EndPoint 00000011@127.0.0.1 resumed
    18:49:10.141|MediaServer.cpp(684)|Log2||??: references to call 00000008 were removed
    18:49:10.141|MSCallConf.cpp(30)|Log2||??: Call: 00000008 destroyed
    18:49:10.161|MediaServer.cpp(386)|Log2||??: references to EndPoint 00000011@127.0.0.1 were removed
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Open registry editor and remove "msExternalInterface" and "msLocalInterface" values under key HKEY_LOCAL_MACHINE\Software\3CX\PhoneSystem.
    I cannot imagine why these values was initialized to 127.0.0.1... It seems PC was not connected to network when you install phonesystem...
    Stepan
  5. marcovalli
    Feb 26, 2007
    14
    Thank.
    Effectively when I have installed the software the was not connected to network .
