Audio problems.
Discussion in '3CX Phone System - General' started by evo8, Aug 25, 2010.
  1. evo8
    Jul 6, 2010
    11
    We are running 3 sip trunks (VoiceFlex) on our 3cx (P4 2.2 with 1Gb ram XP pro) and currently only 3 extensions. When only one extension is being used for an external call it works fine, but as soon as another call comes in the audio on the call is illegible, I suppose you could call it jitter. The internet is not being used very much and the switch has qos configured for those devices. Any ideas?
    10,368
    228
    Have you run a speed test on your internet connection? Sometimes the download speed is much much greater than the upload speed. Is there a hub rather than a switch used on your network?
  3. evo8
    Jul 6, 2010
    11
    The switch is a ProCurve 2626 and the phones and PC's have their own ethernet ports. The router reports that it is connected at 3072kbps with an upload of 832kbps (last time I checked the speeds were 2.2Mbps and 0.69Mbps).
