Audio quality of MoH/IVR/Queue recordings
Discussion in 'Ideas' started by brendan.helsham, Apr 19, 2016.
Audio quality of MoH/IVR/Queue recordings 5 5 6votes
5/5, 6 votes
  1. brendan.helsham
    Jan 23, 2008
    36
    5
    Is it possible to implement support for higher quality recordings used for MoH, Queue, IVR recordings? I find that the quality of the standard 8KHz, 16-bit, mono a little disappointing, especially when using HD codecs.
    Cheers
    -Brendan
  2. sean.suntelnetworks
    Oct 10, 2014
    34
    The quality is actually lower than this, since the current v14 software uses ADPCM. (around 4-5k sample rate)
    Its crap quality. Ive complained about this over and over.
  3. sean.suntelnetworks
    Oct 10, 2014
    34
    Btw, here's the link to a post when we first started upgrading systems to v14.
    version-14-audio-recording-and-voicemail-format-42276.html
    There's a reason why ADPCM isn't used for most phone systems... the sound quality away from ulaw is noticably, and the sound quality away from g722 is so far ADPCM sounds like garbage.
    This needs to be changed.
  4. Gerald Warren
    Oct 22, 2015
    19
    Is this still the current supported audio format in v14 SP3?!
  5. coreybrett81
    Nov 11, 2016
    54
    8
    Attn: 3CX developers- We need normal PCM back ASAP! This is a real buzz kill for Google Apps customers.
  6. easydone
    Nov 22, 2016
    8
    Yeah, this is a dealbreaker.
  7. palmaz
    Aug 22, 2017
    43
    18
