Audio Volume Control
Discussion in 'Ideas' started by hive, Nov 16, 2016.
Audio Volume Control 5 5 2votes
5/5, 2 votes
  1. hive
    Dec 9, 2014
    We've had many requests from sites to allow a volume control on the 3CX UI for audio files. Something like a slider volume control that would show up next to any audio file loaded for voicemail or hold music that would allow users to control the volume without resampling the audio file manually and re-uploading it.
  2. cel
    cel
    Jul 15, 2015
    34
    23
    I would even have a sort of slider during an active call in the UI for changing/adapting the audio stream. This is thin I really Missing as I daily using the Windows 3CX Phone and the volume need sometimes to be adapted due to the external volume quality.
