audiocode MP-114: Pots doesn't hang up
Discussion in '3CX Phone System - General' started by alicic, Jan 16, 2008.
  1. alicic
    alicic New Member
    Oct 3, 2007
    119
    You have to update to new frmware of MP114. The newst frimware is MP118_SIP_F5.20A.026.007.cmp .
    You have the problem with call disconnect tones that is why it is not disconecting correctly. Ask from your AudioCodes Distributer to send you the "call progress tone files". There are files for different countries. Files are in format .dat You upload them and then your MP114 should disconnect correctly.
    What country you are in
    regards,
