Audiocodes Documentation Error?
Discussion in '3CX Phone System - General' started by RichardU, Jan 4, 2008.
  1. RichardU
    Dec 12, 2007
    7
    The following section is from the 3CX documentation for AudioCodes.
    It says the default gateway is 10.172.0.1 and then it says to set the Default Gateway to 10.172.0.253. Is this an error in the documentation?
    Richard
    From this point onwards, we will assume that the IP Address of the 3CX PBX Server on the network is 10.172.0.2, the IP Address of the device will be 10.172.0.207, the IP Address of the default gateway and DNS Server for the subnet is 10.172.0.1, and the address of the computer used to configure the device will be 10.172.0.124.
    a. In the “IP Configuration” section, set the IP Address for the device to “10.172.0.207”.
    b. Leave the “NAT IP Address” default – “0.0.0.0”.
    c. Set the “Subnet Mask” to “255.255.255.0”.
    d. Set the “Default Gateway Address” to “10.172.0.253”.
    e. In the “SIP Parameters” section, set “Gateway Name” to “10.172.0.207”.
    f. Set the “Working with Proxy” field to “Yes”.
    g. Set the fields labeled “Proxy IP Address” and “Proxy Name” to “10.172.0.2”.
    h. Set the “Enable Registration” field to “Enable”.
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Hey thanks for pointing that out. At the time when we wrote it initially we were using 253 as gateway but later on when we revised the documentation we had already reverting to a gateway on ip .1 on the test network were we use these devices to create these configurations. So If anything I would call it a minor oversight rather than an error :D We will fix it asap.
