AudioCodes MP-104
Discussion in 'Windows' started by Dale, Apr 7, 2010.
  1. Dale
    Apr 7, 2010
    I am currently running a linux version of asterisk, but since I am on the road more these days than not, looking at going to a windows based solution to make it easier on the family to look after if I am away. I am currently using an Audiocodes MP-104, FXO with 4 Polycom phones (2 601's, 2 500's). Anyone have any experience with setting this up with 3CX under Windows 2003?
    I don't see any of my hardware on the supported list, but I have a feeling it should work. Can I use the MP-114 config as a reference for the MP-104 setup? Since Polycom's are not on the list, I figure how hard could it be to set them up since I did it under the linux version. Any suggestions?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
  3. Dale
    Apr 7, 2010
    Thanks for the link for the Polycoms. The MP-104 is replacing a 400P, just waiting for a friend to dig it out of his garage :lol:
