AudioCodes MP-114 FXO
Discussion in '3CX Phone System - General' started by onsite, Jan 23, 2008.
  1. onsite
    Jan 23, 2008
    We can't make out going calls.
    IP Phone: Grandstream 2000
    3XC softphone
    AudioCodes MP-114 FXO w/4 PTSN lines from Verizon
    Phone can call each other via thier extensions but can't call someone cell phone for example.
    All line are registered in 3cx.
    I followed the setup guide from 3cx webpage to the letter, excecpt ip address of course.
    Grandstream says "404 NOT FOUND wrong number or party not online."
    Any ideas?
    Below is a from the Server Status page:
    13:10:35.812 Call::Terminate [CM503008]: Call(11): Call is terminated
    13:10:35.781 Call::RouteFailed [CM503014]: Call(11): Attempt to reach [sip:919738682237@192.168.1.5:5060] failed. Reason: Not Found
    13:10:35.765 CallLeg::eek:nFailure [CM503003]: Call(11): Call to sip:237@192.168.1.10:5060 has failed; Cause: 404 Not Found; from IP:192.168.1.10
    13:10:35.609 CallLeg::eek:nFailure [CM503003]: Call(11): Call to sip:237@192.168.1.10:5060 has failed; Cause: 404 Not Found; from IP:192.168.1.10
    13:10:35.468 CallLeg::eek:nFailure [CM503003]: Call(11): Call to sip:237@192.168.1.10:5060 has failed; Cause: 404 Not Found; from IP:192.168.1.10
    13:10:35.312 CallLeg::eek:nFailure [CM503003]: Call(11): Call to sip:237@192.168.1.10:5060 has failed; Cause: 404 Not Found; from IP:192.168.1.10
    13:10:35.171 CallLeg::eek:nFailure [CM503003]: Call(11): Call to sip:237@192.168.1.10:5060 has failed; Cause: 404 Not Found; from IP:192.168.1.10
    13:10:35.031 CallLeg::eek:nFailure [CM503003]: Call(11): Call to sip:237@192.168.1.10:5060 has failed; Cause: 404 Not Found; from IP:192.168.1.10
    13:10:34.890 CallLeg::eek:nFailure [CM503003]: Call(11): Call to sip:237@192.168.1.10:5060 has failed; Cause: 404 Not Found; from IP:192.168.1.10
    13:10:34.734 CallLeg::eek:nFailure [CM503003]: Call(11): Call to sip:237@192.168.1.10:5060 has failed; Cause: 404 Not Found; from IP:192.168.1.10
    13:10:34.578 CallLeg::eek:nFailure [CM503003]: Call(11): Call to sip:237@192.168.1.10:5060 has failed; Cause: 404 Not Found; from IP:192.168.1.10
    13:10:34.421 CallLeg::eek:nFailure [CM503003]: Call(11): Call to sip:237@192.168.1.10:5060 has failed; Cause: 404 Not Found; from IP:192.168.1.10
    13:10:34.375 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(11): Calling: PSTNline:10801@[Dev:sip:10801@192.168.1.10:5060, Dev:sip:10802@192.168.1.10:5060, Dev:sip:10803@192.168.1.10:5060]
    13:10:33.968 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(11): Calling: PSTNline:10801@[Dev:sip:10801@192.168.1.10:5060, Dev:sip:10802@192.168.1.10:5060, Dev:sip:10803@192.168.1.10:5060]
    13:10:33.250 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(11): Calling: PSTNline:10800@[Dev:sip:10800@192.168.1.10:5060, Dev:sip:10801@192.168.1.10:5060, Dev:sip:10802@192.168.1.10:5060, Dev:sip:10803@192.168.1.10:5060]
    13:10:32.546 CallCtrl::eek:nIncomingCall [CM503001]: Call(11): Incoming call from Ext.199 to [sip:919738682237@192.168.1.5:5060]
    OST
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    Hallo,
    It seems that you did not configure Outgoing Rules. Please see configure it and it has to work
    regards
  3. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    Exactly! I've got MP-1140 FXO and it causes no problems if configured properly.
    Thank you
    Marcin
  4. onsite
    Jan 23, 2008
    I do have outgoing rule.
    Calls to Numbers starting with (Prefix) : 9
    Calls from extension(s): 100-199
    Calls to Numbers with a length of: 10
    Route1 AudioCodeMP114 Skip Digit 9
  5. onsite
    Jan 23, 2008
    Found my problem.
    It was on the AudioCodes.
    3CX's how to on how to setup the AudioCodes isn't all that great.
    There are a number of other settings that must be made.
    For those of you who are having difficulties like we were use the below INI info as a template.
    Below is the content of my INI file that finally got it working.
    The ip address have been change to protect the inocent.
    :lol:
    ;** Ini File **
    ;Board: MP-114 FXO
    ;Serial Number: 1063251
    ;Slot Number: 1
    ;Software Version: 5.20A.024.002
    ;DSP Software Version: 204IM => 520.12
    ;Board IP Address: 192.168.1.10
    ;Board Subnet Mask: 255.255.255.0
    ;Board Default Gateway: 192.168.1.1
    ;Ram size: 32M Flash size: 8M
    ;Num DSPs: 1 Num DSP channels: 4
    ;Profile: NONE
    [SYSTEM Params]
    DNSPriServerIP = 192.168.1.1
    SyslogServerIP = 0.0.0.0
    EnableSyslog = 1
    VXMLFIleName = ''
    SyslogServerPort = 514
    [BSP Params]
    PCMLawSelect = 3
    EnableLANWatchdog = 0
    LocalMediaDefaultGW = 192.168.1.1
    LocalMediaIPAddress = 192.168.1.10
    LocalMediaSubnetMask = 255.255.255.0
    LocalControlIPAddress = 192.168.1.10
    LocalControlSubnetMask = 255.255.255.0
    LocalControlDefaultGW = 192.168.1.1
    LocalOAMIPAddress = 192.168.1.10
    LocalOAMSubnetMask = 255.255.255.0
    LocalOAMDefaultGW = 192.168.1.1
    RoutingTableHopsCountColumn = 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
    [ATM Params]
    [Analog Params]
    MinFlashHookTime = 100
    FXSLoopCharacteristicsFilename = 'MP11x-02-1-FXS_16KHZ.dat'
    CurrentDisconnectDuration = 500
    [ControlProtocols Params]
    AdminStateLockControl = -1
    [MGCP Params]
    [MEGACO Params]
    DIGITMAPPING = ''
    EP_Num_0 = 0
    EP_Num_1 = 1
    EP_Num_2 = 0
    EP_Num_3 = 0
    EP_Num_4 = 0
    [PSTN Params]
    [SS7 Params]
    [Voice Engine Params]
    EnableSilenceCompression = 0
    EnableEchoCanceller = 1
    VoiceVolume = 0
    InputGain = 0
    BrokenConnectionEventTimeout = 100
    DTMFVolume = -11
    DTMFTransportType = 3
    MFTransportType = 3
    CallerIDType = 0
    DJBufMinDelay = 70
    RFC2833PayloadType = 101
    EnableAnswerDetector = 0
    AnswerDetectorActivityDelay = 0
    AnswerDetectorSilenceTime = 10
    AnswerDetectorRedirection = 0
    AnswerDetectorSensitivity = 0
    FarEndDisconnectSilenceMethod = 2
    FarEndDisconnectSilencePeriod = 120
    CallProgressTonesFilename = 'usa_tones_12.dat'
    [WEB Params]
    LogoWidth = '339'
    [SIP Params]
    ENABLECALLERID = 1
    MAXDIGITS = 49
    NUMBEROFWAITINGINDICATIONS = 2
    ALWAYSUSEROUTETABLE = 0
    ENABLECALLWAITING = 1
    TIMEBETWEENWAITINGINDICATIONS = 10
    TIMEBETWEENDIGITS = 4
    TIMEFORDIALTONE = 16
    ISSPECIALDIGITS = 0
    REGISTRATIONTIME = 180
    DISCONNECTONBUSYTONE = 1
    ISPROXYUSED = 0
    ISREGISTERNEEDED = 0
    AUTHENTICATIONMODE = 0
    ISWAITFORDIALTONE = 1
    ISTWOSTAGEDIAL = 0
    ROUTEMODETEL2IP = 0
    FXOBETWEENRINGTIME = 8
    ENABLECURRENTDISCONNECT = 1
    ENABLEREVERSALPOLARITY = 0
    SECURECALLSFROMIP = 0
    ENABLEBUSYOUT = 0
    ENABLEHOLD = 1
    ENABLEFORWARD = 1
    CDRREPORTLEVEL = 0
    MAXACTIVECALLS = 8
    CHANNELSELECTMODE = 2
    GWDEBUGLEVEL = 5
    ENABLEPROXYKEEPALIVE = 0
    ENABLEEARLYMEDIA = 1
    DEFAULTNUMBER = '1000'
    PROXYNAME = '192.168.1.5'
    REGISTRARIP = ''
    SIPGATEWAYNAME = '192.168.1.5'
    USERNAME = ''
    CNONCE = 'Default_Cnonce'
    PASSWORD = 'Default_Passwd'
    ENABLESILENCEDISCONNECT = 0
    ENABLEVOICEDETECTION = 0
    DEFAULTRELEASECAUSE = 3
    PROGRESSINDICATOR2IP = -1
    RXDTMFOPTION = 3
    ISFALLBACKUSED = 0
    ALWAYSSENDTOPROXY = 0
    ISPROXYHOTSWAP = 0
    PROXYKEEPALIVETIME = 60
    PROXYREDUNDANCYMODE = 0
    FILTERCALLS2IP = 0
    PRACKMODE = 0
    GWAPPDELAYTIME = 7
    ENABLEDIDWINK = 0
    DISCONNECTONBROKENCONNECTION = 0
    STUTTERTONEDURATION = 2000
    ENABLEDIGITDELIVERY = 0
    WAITINGBEEPDURATION = 300
    SENDINVITETOPROXY = 0
    XFERPREFIX = ''
    CDRSYSLOGSERVERIP = 0.0.0.0
    REGISTRATIONRETRYTIME = 30
    MWIEXPIRATIONTIME = 7200
    SUBSCRIBERETRYTIME = 120
    ENABLEMWISUBSCRIPTION = 0
    MWISERVERIP = ''
    MWIANALOGLAMP = 0
    MWIDISPLAY = 0
    ENABLEMWI = 0
    USEGATEWAYNAMEFOROPTIONS = 0
    PSTNALERTTIMEOUT = 180
    PREFERROUTETABLE = 0
    ENABLEDIGITDELIVERY2IP = 0
    ISFAXUSED = 1
    SUBSCRIPTIONMODE = 0
    HOLDFORMAT = 0
    GWREGISTRATIONNAME = ''
    TIMEBEFOREWAITINGINDICATIONS = 0
    SENDMETERING2IP = 0
    MAXCALLDURATION = 0
    REGISTRARNAME = ''
    REGISTRATIONTIMEDIVIDER = 50
    RINGSBEFORECALLERID = 1
    HOTLINETONEDURATION = 16
    ENABLETRANSFER = 1
    ENABLEUSERINFOUSAGE = 0
    GUARDTIMEBETWEENCALLS = 1
    DISCONNECTONDIALTONE = 0
    [VXML Params]
    [IPsec Params]
    [Audio Staging Params]
    DisableSNMP = 0
    SNMPTrapManagerHostName = ''
    ; *** TABLE DspTemplates ***
    ; This table contains hidden elements and will not be exposed.
    ; This table exists on board and will be saved during restarts
    ; *** TABLE PREFIX ***
    [ PREFIX ]
    FORMAT PREFIX_Index = PREFIX_DestinationPrefix, PREFIX_DestAddress, PREFIX_SourcePrefix, PREFIX_ProfileId, PREFIX_MeteringCode;
    PREFIX 0 = *, 192.168.1.5, *, 0, 255;
    [ \PREFIX ]
    ; *** TABLE CoderName ***
    [ CoderName ]
    FORMAT CoderName_Index = CoderName_Type, CoderName_PacketInterval, CoderName_rate, CoderName_PayloadType, CoderName_Sce;
    CoderName 0 = g711Ulaw64k, 20, 0, 0, 0;
    CoderName 1 = g711Alaw64k, 20, 0, 8, 0;
    CoderName 5 = g711Ulaw64k, 20, 0, 255, 0;
    CoderName 6 = g711Alaw64k, 20, 0, 255, 0;
    [ \CoderName ]
    ; *** TABLE TrunkGroup ***
    [ TrunkGroup ]
    FORMAT TrunkGroup_Index = TrunkGroup_TrunkGroupNum, TrunkGroup_FirstTrunkId, TrunkGroup_FirstBChannel, TrunkGroup_LastBChannel, TrunkGroup_FirstPhoneNumber, TrunkGroup_ProfileId, TrunkGroup_LastTrunkId, TrunkGroup_Module;
    TrunkGroup 0 = 1, 255, 1, 1, 10800, 0, 255, 255;
    TrunkGroup 1 = 1, 255, 2, 2, 10801, 0, 255, 255;
    TrunkGroup 2 = 1, 255, 3, 3, 10802, 0, 255, 255;
    TrunkGroup 3 = 1, 255, 4, 4, 10803, 0, 255, 255;
    TrunkGroup 4 = 1, 255, 5, 5, 105, 0, 255, 0;
    TrunkGroup 5 = 1, 255, 6, 6, 106, 0, 255, 0;
    TrunkGroup 6 = 1, 255, 7, 7, 107, 0, 255, 0;
    TrunkGroup 7 = 1, 255, 8, 8, 108, 0, 255, 0;
    [ \TrunkGroup ]
    ; *** TABLE PstnPrefix ***
    [ PstnPrefix ]
    FORMAT PstnPrefix_Index = PstnPrefix_DestPrefix, PstnPrefix_TrunkGroupId, PstnPrefix_SourcePrefix, PstnPrefix_SourceAddress, PstnPrefix_ProfileId;
    PstnPrefix 0 = *, 1, *, *, 0;
    [ \PstnPrefix ]
    ; *** TABLE ProxyIp ***
    [ ProxyIp ]
    FORMAT ProxyIp_Index = ProxyIp_IpAddress;
    ProxyIp 0 = 192.168.1.5;
    [ \ProxyIp ]
    ; *** TABLE TxDtmfOption ***
    [ TxDtmfOption ]
    FORMAT TxDtmfOption_Index = TxDtmfOption_Type;
    TxDtmfOption 0 = 4;
    TxDtmfOption 1 = 2;
    [ \TxDtmfOption ]
    ; *** TABLE TrunkGroupSettings ***
    [ TrunkGroupSettings ]
    FORMAT TrunkGroupSettings_Index = TrunkGroupSettings_TrunkGroupId, TrunkGroupSettings_ChannelSelectMode, TrunkGroupSettings_RegistrationMode, TrunkGroupSettings_GatewayName;
    TrunkGroupSettings 0 = 1, 1, 255, ;
    [ \TrunkGroupSettings ]
    ; *** TABLE TelProfile ***
    [ TelProfile ]
    FORMAT TelProfile_Index = TelProfile_ProfileName, TelProfile_TelPreference, TelProfile_CodersGroupID, TelProfile_IsFaxUsed, TelProfile_JitterBufMinDelay, TelProfile_JitterBufOptFactor, TelProfile_IPDiffServ, TelProfile_SigIPDiffServ, TelProfile_DtmfVolume, TelProfile_InputGain, TelProfile_VoiceVolume, TelProfile_EnableReversePolarity, TelProfile_EnableCurrentDisconnect, TelProfile_EnableDigitDelivery, TelProfile_EnableEC, TelProfile_MWIAnalog, TelProfile_MWIDisplay, TelProfile_FlashHookPeriod, TelProfile_EnableEarlyMedia, TelProfile_ProgressIndicator2IP, TelProfile_TimeForReorderTone;
    TelProfile 1 = "Default Tel Profile", 1, 0, 1, 70, 10, 46, 40, -11, 0, 0, 0, 0, 0, 1, 0, 0, 400, 1, 0, 255;
    [ \TelProfile ]
    ; *** TABLE EnableCallerId ***
    [ EnableCallerId ]
    FORMAT EnableCallerId_Index = EnableCallerId_IsEnabled;
    EnableCallerId 0 = 1;
    EnableCallerId 1 = 1;
    EnableCallerId 2 = 1;
    EnableCallerId 3 = 1;
    [ \EnableCallerId ]
    ; *** TABLE TargetOfChannel ***
    [ TargetOfChannel ]
    FORMAT TargetOfChannel_Index = TargetOfChannel_Destination, TargetOfChannel_Type;
    TargetOfChannel 0 = 10800, 1;
    TargetOfChannel 1 = 10801, 1;
    TargetOfChannel 2 = 10802, 1;
    TargetOfChannel 3 = 10803, 1;
    [ \TargetOfChannel ]
    ; *** TABLE Authentication ***
    [ Authentication ]
    FORMAT Authentication_Index = Authentication_UserId, Authentication_UserPassword;
    Authentication 0 = 10800, 10800;
    Authentication 1 = 10801, 10801;
    Authentication 2 = 10802, 10802;
    Authentication 3 = 10803, 10803;
    [ \Authentication ]
  6. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,915
    223
    We are sure the config guide works well. It has been re checked several times. If you follow the step by step guide, you can not go wrong.
    it maybe that you have some exceptional setup - in that case it would be helpful is if you mentioned what setting you had to make in your case to make it work....
  7. LLangston
    Aug 27, 2007
    57
    We are using the Audio Codes MP-114 FXO gateway as well but with the Polycom Soundpoint 501 phones. I had to set the Automatic Dialing to Enable instead of Hotline for everything to work.
    Just a FYI we have been working with tech support with Audio Codes on a couple of issues, one of which was a rushing or 'ocean' sound whenever we would begin talking that would only stop when we stopped talking. We found that by setting the ECDCRemoval to a value of 1 we eliminated that.
  8. alicic
    alicic New Member
    Oct 3, 2007
    119
    I would also agree, instead HOTLINE put ENABLE, and you will receive incoming cals on MP 114.
    regards,
  9. Nick Galea
    Jun 6, 2006
    1,915
    223
    OK, thanks for the feedback. You are right, we have updated the config guide to reflect this
  10. mindcrime
    Apr 25, 2008
    First, sorry to drag up an old topic, but I thought this information might help somebody else.
    Not to be argumentative, but I have to agree with onsite on this one. I could not get my Audiocodes mp-118 fxo to work with the 3cx config document, either. Using the config document, I was able to get inbound calls and extension to extension calls to work with no problems; however, I never could place an outbound call no matter how I tweaked the rules or other settings.
    I imported onsite's ini file into my mp-118 after changing the appropriate email addresses, and I was immediately able to make an outbound call.
    This was my old config file:
    My test set includes a new Dell server running the latest build of 3cx (free version), a Polycom IP 330 phone, an Audicodes mp-118fxo with the 5.2 firmware, and one regular pstn line plugged into fxo port 2.
    I can see several places where our configs don't match up; I would appreciate it if comebody could explain to me why the 3cx setup document didn't produce the desired results.
    ;** Ini File **
    ;Board: MP-118 FXO
    ;Serial Number: xxxxxxx
    ;Slot Number: 1
    ;Software Version: 5.20A.040
    ;DSP Software Version: 204IM => 520.16
    ;Board IP Address: 10.125.0.60
    ;Board Subnet Mask: 255.255.0.0
    ;Board Default Gateway: 10.125.0.50
    ;Num DSPs: 2 Num DSP channels: 8
    ;Profile: NONE
    [SYSTEM Params]
    DNSPriServerIP = 10.125.0.1
    SyslogServerIP = 10.1.1.89
    [BSP Params]
    PCMLawSelect = 3
    [ATM Params]
    [Analog Params]
    [MGCP Params]
    [MEGACO Params]
    EP_Num_0 = 0
    EP_Num_1 = 1
    EP_Num_2 = 0
    EP_Num_3 = 0
    EP_Num_4 = 0
    [PSTN Params]
    [SS7 Params]
    VoiceVolume = 10
    DJBufMinDelay = 70
    [WEB Params]
    LogoWidth = '339'
    [SIP Params]
    MAXDIGITS = 49
    ISPROXYUSED = 1
    ISREGISTERNEEDED = 1
    ISTWOSTAGEDIAL = 0
    ROUTEMODETEL2IP = 0
    ENABLEREVERSALPOLARITY = 1
    GWDEBUGLEVEL = 5
    PROXYNAME = 'Pegasus'
    REGISTRARIP = ''
    SIPGATEWAYNAME = '10.125.0.1'
    USERNAME = ''
    ENABLEVOICEDETECTION = 1
    ISFALLBACKUSED = 0
    ISPROXYHOTSWAP = 0
    PRACKMODE = 0
    ISFAXUSED = 1
    REGISTRARNAME = ''
    [VXML Params]
    [IPsec Params]
    [ PREFIX ]
    PREFIX 0 = 10, 10.125.0.1, *, 0, 255;
    [ \PREFIX ]
    [ CoderName ]
    CoderName 2 = g729, 20, 0, 18, 0;
    CoderName 3 = t38fax, 255, 255, 0, -1;
    [ \CoderName ]
    [ TrunkGroup ]
    TrunkGroup 0 = 0, 255, 1, 1, 10800, 1, 255, 0;
    TrunkGroup 1 = 0, 255, 2, 2, 10801, 1, 255, 0;
    TrunkGroup 2 = 0, 255, 3, 3, 10802, 1, 255, 0;
    TrunkGroup 3 = 0, 255, 4, 4, 10803, 1, 255, 0;
    TrunkGroup 4 = 0, 255, 5, 5, 10804, 1, 255, 0;
    TrunkGroup 5 = 0, 255, 6, 6, 10805, 1, 255, 0;
    TrunkGroup 6 = 0, 255, 7, 7, 10806, 1, 255, 0;
    TrunkGroup 7 = 0, 255, 8, 8, 10807, 1, 255, 0;
    [ \TrunkGroup ]
    [ PstnPrefix ]
    [ \PstnPrefix ]
    [ ProxyIp ]
    ProxyIp 0 = 10.125.0.1;
    [ \ProxyIp ]
    [ TxDtmfOption ]
    TxDtmfOption 0 = 4;
    [ \TxDtmfOption ]
    [ TelProfile ]
    [ \TelProfile ]
    [ EnableCallerId ]
    EnableCallerId 4 = 1;
    EnableCallerId 5 = 1;
    EnableCallerId 6 = 1;
    EnableCallerId 7 = 1;
    [ \EnableCallerId ]
    ; *** TABLE CallerDisplayInfo ***
    [ CallerDisplayInfo ]
    FORMAT CallerDisplayInfo_Index = CallerDisplayInfo_DisplayString, CallerDisplayInfo_IsCidRestricted;
    CallerDisplayInfo 0 = 10800, 0;
    CallerDisplayInfo 1 = 10801, 0;
    CallerDisplayInfo 2 = 10802, 0;
    CallerDisplayInfo 3 = 10803, 0;
    CallerDisplayInfo 4 = 10804, 0;
    CallerDisplayInfo 5 = 10805, 0;
    CallerDisplayInfo 6 = 10806, 0;
    CallerDisplayInfo 7 = 10807, 0;
    [ \CallerDisplayInfo ]
    [ TargetOfChannel ]
    TargetOfChannel 4 = 10804, 1;
    TargetOfChannel 5 = 10805, 1;
    TargetOfChannel 6 = 10806, 1;
    TargetOfChannel 7 = 10807, 1;
    [ Authentication ]
    Authentication 4 = 10804, 10804;
    Authentication 5 = 10805, 10805;
    Authentication 6 = 10806, 10806;
    Authentication 7 = 10807, 10807;
    [ \Authentication ]
    Thanks,
  11. carlosar
    Jan 7, 2008
    15
    Hello everyone.
    Please does anyone can bring me the firmware 5.2 for the MP-114?
    Thanks in advance.
  12. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I just registered with AudioCodes support. You just need your serial # and device. I have a temp ID that was emailed but that only got me to the docs for it. My distributor has all the firmware but nothing is listed for 5.2 for the MP-114. Only 5.2 for the MP-118. Not sure if it will work or not.
  13. craigw
    Jul 24, 2007
    9
    I have a MP-118 FXO Gateway. I was not able to get it working until I clicked on Protocol Management. Then at the top I clicked on Routing Tables and under that Tel to IP Routing. Under there I changed the Dest. IP Address to the IP address of my 3CX server and then everything started working. Maybe I missed something in the instructions but I did not see that in the Configuration instructions for AudioCodes MP-114 & MP-118. I hope this can help someone.
    Craig
