AudioCodes MP-114 FXS
Discussion in '3CX Phone System - General' started by richie314nj, Jan 21, 2008.
  1. richie314nj
    Jun 22, 2007
    19
    I have 4 POT lines from Verizon going in to an AudioCodes MP-114 FXS gateway.
    4 Grandstream GPX2000 phones
    When trying to make a call the line rings and rings but the recievers end never does. The call doesn't seem to be making it out.
    LOG
    11:00:44.000 Call::Terminate [CM503008]: Call(28): Call is terminated
    11:00:23.046 Line::printEndpointInfo [CM505002]: Gateway:[AudioCodes FXS] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Audiocodes-Sip-Gateway-MP-114 FXS/v.5.00A.024] Transport: [sip:192.168.1.5:5060]
    11:00:22.984 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(28): Calling: PSTNline:10802@[Dev:sip:10802@192.168.1.10:5060, Dev:sip:10803@192.168.1.10:5060, Dev:sip:10800@192.168.1.10:5060]
    11:00:22.406 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(28): Calling: PSTNline:10801@[Dev:sip:10801@192.168.1.10:5060, Dev:sip:10802@192.168.1.10:5060, Dev:sip:10803@192.168.1.10:5060, Dev:sip:10800@192.168.1.10:5060]
    11:00:21.250 CallCtrl::eek:nIncomingCall [CM503001]: Call(28): Incoming call from Ext.199 to [sip:99738682237@192.168.1.5:5060]
    10:59:18.984 Call::Terminate [CM503008]: Call(27): Call is terminated
    10:58:54.125 Line::printEndpointInfo [CM505002]: Gateway:[AudioCodes FXS] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Audiocodes-Sip-Gateway-MP-114 FXS/v.5.00A.024] Transport: [sip:192.168.1.5:5060]
    10:58:54.078 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(27): Calling: PSTNline:10802@[Dev:sip:10802@192.168.1.10:5060, Dev:sip:10803@192.168.1.10:5060, Dev:sip:10800@192.168.1.10:5060]
    10:58:53.031 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(27): Calling: PSTNline:10801@[Dev:sip:10801@192.168.1.10:5060, Dev:sip:10802@192.168.1.10:5060, Dev:sip:10803@192.168.1.10:5060, Dev:sip:10800@192.168.1.10:5060]
    10:58:51.531 CallCtrl::eek:nIncomingCall [CM503001]: Call(27): Incoming call from Ext.199 to [sip:99738682237@192.168.1.5:5060]
    10:51:55.500 ExtnCfg::updateContact [CM504001]: Ext.199: new contact is registered. Contact(s): [sip:199@127.0.0.1:5070;rinstance=fb1ea70006237721/199]
    10:51:39.140 ExtnCfg::updateContact [CM504001]: Ext.101: new contact is registered. Contact(s): [sip:101@192.168.1.104:5060;transport=udp/101]
    10:43:54.343 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:888@3CXPhoneSystem with contact sip:888@192.168.1.5:5100;user=phone
    10:43:54.000 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
    10:42:36.156 StunClient::process [CM506003]: Resolved SIP external IP:port has changed to (68.236.216.212:2544) on Transport 192.168.1.5:5060
    10:42:36.000 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.5:5060
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Richie,
    It seems using incorrect gateway. FXS port for analog phone connect to IPPBX. FXO port for phone line which from Telco (PSTN line provider) connect to IPPBX.
