AudioCodes MP-11x 5.2 Firmware ** SOLVED
Discussion in '3CX Phone System - General' started by AndrewRTS, Nov 22, 2007.
  1. AndrewRTS
    Aug 8, 2007
    39
    Can any of you PM me and send the 5.2 revision of the AudioCodes MP-11x firmware? I know it exists and will solve many of our issues... I just can't get registered on the AudioCodes site, and the place we bought our gateway from has yet to respond. My staff is going a bit batty without Caller ID. :)
    Thanks!!
    -A
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Let me know your email address. My email is 5qg4(at)ccx.ath.cx
  3. AndrewRTS
    Aug 8, 2007
    39
    Thanks so much for the quick send! Our Caller-ID problems went away immediately!
    Now if I can just fisk the pesky "no hangup on voicemail" bug! We are in the US and it is setup tha way, but our CLEC seems to use a slightly different disconnect tone... GRRRR
    Thanks again, Ricky!!
    -A
  4. malimar
    Oct 26, 2010
    10
    Re: AudioCodes MP-11x 5.2 Firmware
    I cannot seem to find a place to download version 5.2. Can someone PM me 5.2? I can obtain version 5.8 or 6.0, has anyone experience those version with latest version of 3CX? We currenlty have MP-118.
    Thanks,
  5. semn
    Jan 25, 2010
    21
    At i client i used 1 MP-118 FXO box to interconnect the 3cx pbx with 6 analog lines and also 1 x MP-118 FXS box to connect couple old phones to the new system.
    In the MP-118 FXO i use 5.8 version and everything are ok with a small issue from time to time in the middle of conversion i receive a DTMF sound for a second or tow. With 6.0 in FXO i discover a very nasty issue: if i talk with someone more than 3 minutes and 10 sec the conversion is drop off. I don't know why but this issue is happening only when i use 6.0 version in FXO box.
    In The FXS box i use ver 6.0 and everything are ok.
    George
