AudioCodes MP-408 with 3CX
Discussion in '3CX Phone System - General' started by eddietang, Oct 3, 2007.
  1. eddietang
    Oct 3, 2007
    31
    Has anyone tried using AudioCodes MP-408 VoIP gateways with 3CX?
  2. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    check the manual or see the following manual at
    and see section 6.2.1.2 SIP Proxy & Registration Settings on page number 82 it will give you details for registering your MP-408 to register with 3CX server. enable the register setting and insert the asked information. Add a PSTN gateway in 3CX server and asign the MP-408 username and password and or vice versa and get them connected to each other.
    I hope this informaiton will help you out to configure both 3CX system and even the MP-408 for yourself. [/img]
  3. eddietang
    Oct 3, 2007
    31
    HI
    I managed to get my AudioCodes MP-408 to register with 3CX. I can make outgoing calls but I am unable to receive any incoming calls.
    I get the following message everytime I try to call the number 67799440.
    [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '192.168.1.251'; From: '31168928'; To: '67799440'; Rline: '67799440'; Contact: '31168928'
    Can anyone help ?
    Thanks!
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Go into 3cx web administration and on gateway configuration go to "other options" select "use ip in contacts" and below input '192.168.1.251'
    and then ok.
    It should work after that..
    Cheers
  5. eddietang
    Oct 3, 2007
    31
    I did that and I still can receive a call but now I get the following message.
    [CM101000] Registration request from sip:31168928@192.168.1.250 failed. Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings.
    Eddie
  6. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    According that message.... double check your ID/Pass are set exactly the same on gateway and 3cx.....
    What version you using(3cx) ??
    Cheers
  7. eddietang
    Oct 3, 2007
    31
    Actually the full message I get is the following after I changed the setting you suggested.
    [CM001005] Message SipReq: INVITE 67799440@192.168.1.250:5060 tid=-f1d8-3b0b5f0-607c3b4d cseq=INVITE contact=31168928@192.168.1.251:5060 / 2 from(wire) failed authentication!
    [CM001003] Authentication ID for Ln:10002@AudioCodes-MP408 doesn't match provided: vs 10002
    [CM210001] Ambiguous configuration.4 source lines correspond to incoming call.INVITE Parameters: Contact IP: '192.168.1.251'; From: '31168928'; To: '67799440'; Rline: '67799440'; Contact: '31168928'. Line:CfgExtLine:10002 used as fallback!
    I don't think its a user/pass issue at the number 31168928 is my land line number I am dialing from. I can't possible be creating all the numbers that will be calling into me.
    I am using v3.1.
  8. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    How many lines do you have?
  9. eddietang
    Oct 3, 2007
    31
    I have 2 ISDN BRI lines.
  10. LLangston
    Aug 27, 2007
    57
    In the 3CX management console under Manage Gateways/Other Options do you have the following...
    Caller-ID is in 'user' part of (one of following):
    x 'From' field
    'To' field
    'Request-Line-URI' field
    'Contact' field
    'RemotePartyID;party=calling' field
    Called-Number (for inbound calls) is in:
    'From' field
    x 'To.user' field
    'Request-Line-URI.user' field
    'Contact' field
    'RemotePartyID;party=called' field
    With the x's representing what is ticked in the options offered.
  11. eddietang
    Oct 3, 2007
    31
    Yes I made sure that I have 2 options mentioned selected. I also added a DID entry for my number - 67799440. But I still can't receive any calls into 3CX.
    Below is the following log from the settings:
    [CM101000] Registration request from sip:6590019107@192.168.1.250 failed. Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    [CM001005] Message SipReq: INVITE 67799440@192.168.1.250:5060 tid=-226-86786-51ec9d1f cseq=INVITE contact=6590019107@192.168.1.251:5060 / 2 from(wire) failed authentication!
    [CM001003] Authentication ID for Ln:10001@AudioCodes MP-408 doesn't match provided: vs 10001
    [CM210001] Ambiguous configuration.2 source lines correspond to incoming call.INVITE Parameters: Contact IP: '192.168.1.251'; From: '6590019107'; To: '67799440'; Rline: '67799440'; Contact: '6590019107'. Line:CfgExtLine:10001 used as fallback!
  12. eddietang
    Oct 3, 2007
    31
    Finnaly. I managed to get the incoming call working on the MP-408 with 3CX. Thanks for you all your assistance.
  13. alicic
    alicic New Member
    Oct 3, 2007
    119
    I have the same problem with AudioCodes 402. Can make outside calls but can not receive the calls form outside. Here is my log
    13:11:52.234 AuthMgr::eek:nAuthFailure [CM101000] Registration request from sip:0664xxxxxxx@192.168.10.101 failed. Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    13:11:52.234 AuthMgr::requestCredential [CM001005] Message SipReq: INVITE 01890216110005@192.168.10.101:5060 tid=-899-21965c-1aa199b5 cseq=INVITE contact=0664xxxxxxx@192.168.10.150:5060 / 2 from(wire) failed authentication!
    13:11:52.234 AuthMgr::requestCredential [CM001003] Authentication ID for Ln:10005@Audio Codes 402 BRI doesn't match provided: vs 10005
    13:11:35.359 AuthMgr::eek:nAuthFailure [CM101000] Registration request from sip:0664xxxxxxx@192.168.10.101 failed. Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    13:11:35.359 AuthMgr::requestCredential [CM001005] Message SipReq: INVITE 018902161@192.168.10.101:5060 tid=-888-215476-32a53393 cseq=INVITE contact=0664xxxxxxx@192.168.10.150:5060 / 2 from(wire) failed authentication!
    13:11:35.359 AuthMgr::requestCredential [CM001003] Authentication ID for Ln:10005@Audio Codes 402 BRI doesn't match provided: vs 10005
    13:10:00.125 ServRegs::eek:nAdd [CM113002] Registered: Ln:10005@Audio Codes 402 BRI
    I have given correct passwords and user ids. No mistake with this. I guess there are some other parameters I have configured in 3cx. I have to say that I did:
    'From' field
    'To.user' field
    waiting for your replys,
    regards,
  14. eddietang
    Oct 3, 2007
    31
    For the benefit for all you AudioCodes MP-4xx users, Alicic has already managed to get the incoming calls working.
    But for those of you who has the same issue with a MP-408 or other type of VoIP gateways even after your many attempts to retype the passwords in both your VoIP gateway and 3CX, try removing the SIP user password entirely from AudioCodes and do the same for 3CX. That resolved my problem.
  15. kustura
    Nov 2, 2007
    53
    Thanks guys, setting the passwords for lines to blank solved my problem of 3CX refusing authentication from AudioCodes MP-118.
  16. msola
    Jul 9, 2008
    The MP408 dont allow me to clear the password...
  17. tbdkdk
    Jul 23, 2008
    Re:
    In my latest MP-408 it is not possible to clear the password... :cry:
