Audtio but no video on SIP Calls
Discussion in '3CX Phone System - General' started by amurray7, Feb 15, 2017.
  1. amurray7
    Feb 15, 2017
    We have a Paxton Access intercom panel for video intercom at our main entrance. When the call button is pressed, we accept the call using the Bria app on an iPad and open the door. On Jan 24th, the video stopped working. We use 3CX as a SIP server to make the connection. I am desperate for help at this point as no one can seem to help me get this working. I just updated 3CX to version 15 hoping that would help. Below is the response from Bria technical support.
    Hi Adam,
    Your log is showing that the server is not appreciating the "fast update" parameters sent by Bria for formatting the video encoder, see below:
    From Bria:
    INFO sip:2651@10.101.0.40:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.14.1.206:60218;branch=z9hG4bK-524287-1---62e7df75d378980e;alias
    Max-Forwards: 70
    Contact: <sip:2650@10.14.1.206:60218>
    To: "CO S Main Door"<sip:2651@10.101.0.40:5060>;tag=665d1f65
    Call-ID: N2I4YzhlNDRmNzM1MzY5MjNmZDhmNjk1MjcwYWRjYmY.
    CSeq: 2 INFO
    Content-Type: application/media_control+xml
    User-Agent: Bria iOS release 3.8.2 stamp 37039.37040
    Content-Length: 181
    <?xml version="1.0" encoding="utf-8" ?>
    <media_control>
    <vc_primitive>
    <to_encoder>
    <picture_fast_update />
    </to_encoder>
    </vc_primitive>
    </media_control>
    From Server:
    SIP/2.0 415 Unsupported Media Type
    CSeq: 2 INFO
    Accept: application/dtmf, application/dtmf-relay, application/component-call-info, text/plain
    Content-Length: 0
    This cannot be configured at Bria's end. Would there be any way to get the server to support fast updates?
    Regards,
    Kevin
  2. Ferry Persoon
    Jul 31, 2017
    Kevin
    Did you ever resolved this issue ? ^^
