Australian Prompt Set
Discussion in '3CX Phone System - General' started by markf100, Jun 20, 2017.
  1. markf100
    Jun 11, 2017
    15
    I am unable to locate an Australian prompt set - is this correct?
    Thank you.
  2. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    185
    64
    They were working on one, but didn't know how to pronounce chunder :eek:
  3. markf100
    Jun 11, 2017
    15
    Good point but even the basics would be better as both the US and UK sets are over the top compared to some of the Asterisk sets I have heard over the years.
    Probably to time to remove "chunder" from the primary vocabulary!!
    Thanks for your input.
  4. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    185
    64
    Sorry, but so long as women blow - men will chunder. Can't unsay that one. There are a few Platinum Partners in Oz - maybe one of them would be willing to invest in a prompt set? You can also post it in the ideas forum - slower - but it can get up-voted to help it happen.
  5. bdarcyevans
    Apr 6, 2015
    51
