Authentication Error - v10 Multi-Tenant
Discussion in '3CX Phone System - General' started by packetwire_59, Feb 6, 2012.
  1. packetwire_59
    Jun 30, 2010
    25
    Anyone else see the below authentication error when using 3CX v10 multi-tenant on a Windows 2008 box?
    Thanks,
    Rick
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    What is the exact URL that you accessed when you got this error? Winform works? What web server are you using? Any errors from your web server logs?
  3. packetwire_59
    Jun 30, 2010
    25
    Attempting to access the server via http://serverip:5000 (first tenant install). We only have one tenant on this box, so I can't try any different ports. Using Windows 2008 Server running IIS 7. The 3CX windows management console works fine locally.
    Thanks,
    Rick
  4. danhriscanu
    Nov 29, 2011
    232
    For first tenant port is 5000 for second 6000 and so on. Can you see the first page where you enter your credentials or you see this page from the beginning? Are you accessing your server from local machine or from another machine? If its localhost try accessing from another machine. My opinion is that is something wrong with your IIS. If it doesn't work try to reinstall it.
  5. packetwire_59
    Jun 30, 2010
    25
    When attempting to browse locally on the server (http://localhost:5000) I receive the below message.
    When I browse to the directory, I don't see a default file. Should there be one?
    Thanks,
    Rick
  6. danhriscanu
    Nov 29, 2011
    232
    Try this exact link:
    http://localhost:5000/management
