Authentication failed for SipReq
Discussion in '3CX Phone System - General' started by lewang, Jan 18, 2011.
  1. lewang
    Aug 16, 2010
    8
    I have a system setup using 3CX Phone System Version 9 with SP5. I am using an evaluation license.
    The system is composed of CyberData intercoms and 3CX softphones. I don't have any problems in 'makecall' from softphone to the intercom. However, when I try to use the HTTP API for 'makecall' from intercom to the softphone I get the following:
    16:58:24.484 [CM503008]: Call(4): Call is terminated
    16:58:24.375 [CM102001]: Authentication failed for SipReq: INVITE 1001@127.0.0.1:5060 tid=5e05a430cd51ea0a cseq=INVITE contact=MakeCall@192.168.1.15:5060 / 3 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    16:58:16.953 [CM503007]: Call(4): Device joined: sip:1001@192.168.1.2:5060;line=f66f8173ba5bd27
    16:58:16.953 [CM503007]: Call(4): Device joined: sip:MakeCall@127.0.0.1:40600;rinstance=5b7cbdeef09d981d
    16:58:16.921 [CM505001]: Ext.1001: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cyberdata Intercom v6.0.4] PBX contact: [sip:1001@192.168.1.15:5060]
    16:58:16.921 [CM503002]: Call(4): Alerting sip:1001@192.168.1.2:5060;line=f66f8173ba5bd27
    16:58:15.609 [CM503025]: Call(4): Calling Ext:Ext.1001@[Dev:sip:1001@192.168.1.2:5060;line=f66f8173ba5bd27]
    16:58:15.546 [CM503004]: Call(4): Route 1: Ext:Ext.1001@[Dev:sip:1001@192.168.1.2:5060;line=f66f8173ba5bd27]
    16:58:15.546 [CM503010]: Making route(s) to <sip:1001@127.0.0.1:5060;nofwd=1>
    16:58:15.500 [CM505001]: Ext.MakeCall: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX MakeCall helper;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX MakeCall helper] PBX contact: [sip:MakeCall@127.0.0.1:5060]
    16:58:15.468 [CM503001]: Call(4): Incoming call from Ext.MakeCall to <sip:1001@127.0.0.1:5060;nofwd=1>
    Where 1001 is the extension for the intercom and 1000 is the extension for softphone.
    Could someone please advise why there is authentication failure message? I have double checked the ID and password and they match with the extension settings. Perhaps this is because it is the evaluation version of 3CX Phone System and it is missing the intercom functionality?
    I would appreciate any comments or suggestions.
    Thanks,
    Lei
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    MakeCall uses the PIN of the extension and not the Auth ID.
    Try using that and try again :)
  3. lewang
    Aug 16, 2010
    8
    Do you mean the PIN number used by 3CX Assistant? For simplicity, I have designated 1001 as the extension number, ID, password and the PIN number used by 3CX Assistant. I used the following 'Makecall' command:
    http://localhost:5484/PbxAPI.aspx?func=make_call&from=1001&to=1000&pin=1001
    I have tried reinstalling 3CX Phone System software but it did not help. Please advise.
    Thanks,
    Lei
