Authentication issues
Discussion in 'Windows' started by CHAOS-ITS, Nov 2, 2012.
  1. CHAOS-ITS
    Nov 2, 2012
    I am using 3cx Phone System on a Server 2008 R2 Foundation. I have Logmein Hamachi vpn installed on the the Server and on my laptop. I have a direct vpn tunnel established between the two. When installing the 3cxphone on my laptop and using the auto provision option, the softphone appears in the phones section on the server. I assign it an extension and the provisioning process seem to work because the correct extension number is displayed the the 3xcphone. However, the phone cannot connect stating authentication failure.
    this is the contents of the phone debug;
    Translation file OK
    Translation file OK
    HTTP data provisioning succeeded
    Attempting to connect 5.211.93.108
    Phone requested as local port 5070
    Phone requested local port OK
    Jabra not connected
    RTP engine OK
    SIP engine OK
    Sound mic device OK []
    Sound ring device OK []
    Sound speaker device OK []
    HTTP phonebook provisioning succeeded
    Not connected: Authentication failed
    Phone has been disconnected - error: 403
    Phone is no longer connected
    The tunnel log;
    ConnMgr.cpp(218) : [11:36:35.667](Log2):5.210.174.31:49884 refresh connection 5.210.174.31:49884$5
    TCPSide.cpp(165) : [11:36:36.118](Log2):Master UDP channel is confirmed with 5.210.174.31:49884$5 Master UDP channel is activated
    Tunnel.cpp(150) : [11:36:47.589](Log2):!! Tunnel 'VoipClientConn'(123456) has been disconnected by remote end 5.210.174.31:49884
    Tunnel.cpp(166) : [11:36:47.589](Trace5):Terminating connection 0.0.0.0:0 {s:0274}
    Bridge.cpp(379) : [11:36:47.589](Trace5):processing connection event id=0 from 5.210.174.31:49884
    Bridge.cpp(395) : [11:36:47.589](Trace5):Removing inbound tunnel connection with id=5.210.174.31:49884
    TCPSide.cpp(117) : [11:36:48.595](Log2):Connection destroyed (master side) on socket 628; num.conn=0
    Tunnel.cpp(213) : [11:36:48.595](Log2):Tunnel's thread [4392], serving 'VoipClientConn'(123456) has been shut down
    TCPSide.cpp(105) : [11:37:29.367](Log2):Connection created (master side) on socket 644; num.conn=1
    ConnMgr.cpp(355) : [11:37:29.367](Log2):processing incoming TCP connection from 5.210.174.31:50420
    ConnMgr.cpp(421) : [11:37:30.056](Log2):Accepted connection request from 5.210.174.31:50420 identifying as '123456'(TunnelClient)
    Tunnel.cpp(13) : [11:37:30.056](Log2):** Starting incoming tunnel connection VoipClientConn; id=123456
    Tunnel.cpp(14) : [11:37:30.056](Log2):** Connection from 5.210.174.31:50420
    Bridge.cpp(279) : [11:37:30.057](Log2):** Incoming connection to master-only Tunnel 'VoipClientConn'(123456) is accepted, from 5.210.174.31:50420
    Tunnel.cpp(125) : [11:37:30.057](Log2):Started thread [6604] for connection VoipClientConn at 5.210.174.31:50420
    ConnMgr.cpp(171) : [11:37:32.161](Log2):UDP authentication received from 5.210.174.31:50420 for connection 5.210.174.31:50420$6
    TCPSide.cpp(165) : [11:37:34.222](Log2):Master UDP channel is confirmed with 5.210.174.31:50420$6 Master UDP channel is activated
    ConnMgr.cpp(218) : [11:38:00.521](Log2):5.210.174.31:50420 refresh connection 5.210.174.31:50420$6
    TCPSide.cpp(165) : [11:38:00.970](Log2):Master UDP channel is confirmed with 5.210.174.31:50420$6 Master UDP channel is activated
    any assistance would really be appreciated!
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    can you check the option for that extension, select that extension, tab ""Other" - disallow use of extenison outside the lan.. unselect, block remote tunnel connections also unselect
  3. CHAOS-ITS
    Nov 2, 2012
    Hi There,
    thanks very much, the tunnel option is greyed out but by removing the disallow extension outside the it is now working.
    thanks very much. I appreciate your guidance.
    Kind Regards
  4. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Glad that i helped ;)
