Authentication on INVITE and RE-INVITE
Discussion in '3CX Phone System - General' started by weaver, Nov 13, 2014.
  1. weaver
    Sep 3, 2014
    7
    How can I get the 3cx server to do authentication on a INVITE and RE-INVITE. I can't seem to find the proper setting, and it is in the spec.
  2. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    Hi - Can you describe the problem you are having with 3CX?
    This may be part of the 'VoIP Provider' set up ...
