Authentication password hidden but VoiceMail PIN clear text
Discussion in '3CX Phone System - General' started by MatsW, Apr 9, 2009.
  1. MatsW
    Mar 10, 2009
    50
    How come that the VoiceMail PIN string is not protected by * like the Authentication password? One would normally use the same string, but doing that now would reveal the Authentication password.
  2. instantexpert
    Dec 2, 2008
    92
    I put a feature request over in the "feature request" forum. It seems we are the only ones who consider this a big deal. Given that we're talking about the display setting of one field, I wouldn't presume this to a difficult implementation task.
