Authenticztion failed
Discussion in '3CX Phone System - General' started by KOUSIS, Nov 24, 2010.
  1. KOUSIS
    Nov 17, 2010
    26
    Hello
    I can't call outside numbers with my grandstream 4104 and when i see the logs i have many lines of
    14:22:28.433 [CM102001]: Authentication failed for SipReq: REGISTER domain.ath.cx tid=263972584 cseq=REGISTER contact=204@10.42.44.21:5066 / 9635 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    domain.ath.cx is my DynDNS ip
    Any ideas?
    Thank you
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    The pbx is indiacting that your credentails dont seem to match, im guessing your using this phone as an external extension. If you are convicned that your cerdentials are correct then please use an Ip rather then DynDns adress and see if it connects, if it does work please post back and I will advise the steps to follow.
