- Joined
- Aug 23, 2008
- Messages
- 2
- Reaction score
- 0
Any help would be appreciated. For some reason the contact ip addressing is changing. Any ideas?
[CM102001]: Authentication failed for SipReq: REGISTER 192.168.2.42:5060 tid=e8703d7c29502442 cseq=REGISTER [email protected]:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
14:29:14.278 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.2.42:5060 tid=e3583f0c2c552b3d cseq=REGISTER [email protected]:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
14:29:12.746 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.2.42:5060 tid=c208a61d5a7a543c cseq=REGISTER [email protected]:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
14:29:11.515 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.2.42:5060 tid=6e782337d04eea33 cseq=REGISTER [email protected]:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
14:29:10.313 AuthMgr:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.2.42:5060 tid=0c55aa4df0407878 cseq=REGISTER [email protected]:5070 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
