Authorization
Discussion in 'iOS' started by peterbunn, Dec 8, 2010.
  1. peterbunn
    Jun 3, 2009
    20
    Hi guys,
    I've tried to get the app to work for the past 2 days. I've had no luck. Every time I try and get the phone to authenticate to the pbx I keep on getting this error in the log.
    11:27:59.562 [CM102001]: Authentication failed for SipReq: REGISTER 192.168.80.155 tid=PjAgRaosUP1vV3bHwAO9MZ29YVtIYY6POX cseq=REGISTER contact=joncoles@192.168.80.153:5060 / 62390 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    Now I know that the credentials are correct becuase it's just been auto provisioned.. Anyone else had this error and found a work around?
  2. StefanW
    Jun 2, 2009
    1,222
    93
    Is the EXT ID and the EXT number the same? At the moment it cant be different from the number of the ext. it self
