auto answer make call?
Discussion in 'Windows' started by relact, Feb 6, 2010.
  1. relact
    Feb 2, 2010
    Is it possible to set the 3CX softphone to auto-answer the Make Call ? (via call assistant)
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    3CX Phone has status "Auto Answer" Just right click it icon in the Windows Tray and choose this status.
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,502
    68
    Or by clicking the "Available" online status indicator on the display to toggle.
  4. mdkberry
    Mar 10, 2012
    how about on a mobile device like iPhone or Android can you make it auto-answer voip calls on first ring?
  5. leejor
    10,864
    303
    I'm not sure that you would really want that on a mobile device.
    If you had it enabled for a specific reason, then forgot to turn it off, it would answer while the phone were in your pocket/purse/desk drawer, rather than going off to voicemail, and someone could be eavesdropping on your conversation. That is probably the reason they don't have that sort of a feature for "regular calls" on a mobile, other than perhaps when using a BT headset.
  6. viperadriaan
    Apr 21, 2015
    auto answer
    I need help
    We have a 3cx system, and a PA system, I know its sounds mad, but what is the chance where we can combine the 3cx and the PA system together? Or can the 3cx for windows app, have a auto answering , where they can call to that extension, and be used as a intercom?
  7. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    That is a bit off-topic, you should probably start your own.
    What you need is something to auto-answer a VoIP call and tie into your PA.
    Some say Snom PA1. I've done a Linksys SPA-3102 and Viking RAD.. and a Cyberdata paging amp.. one of those will get what you need done.
  8. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,416
    277
    I use the Snom PA1 - in Multicast mode with Yealink or Grand-stream handsets. Works like a charm.
  9. Brianna Andres
    Aug 18, 2017
    Try this step to enable auto answer call on iPhone : Settings > General > Accessibility > Call Audio Routing > Auto-Answer Calls > Enable it and Set time from 0 to 1 Minute.
