Auto-answer question/problem
Discussion in 'Windows' started by mthibodeau, Feb 27, 2014.
  1. mthibodeau
    Jun 4, 2008
    7
    I need to have the auto-answer feature. I was using it in the old version but I don't see it in the new version... Any idea when it is?
    Thank you
    Bonjour,
    J'ai besoin de la fonctionnalité auto-answer. Je l'utilise présentement avec une vieille version du client mais j'aimerais convertir au dernier client qui ne semble plus l'avoir de disponible... Est-ce que quelqu'un dait où elle se cache
    Merci
  2. norekhov
    3CX Support
    Jan 31, 2014
    53
    The Autoanswer feature is in the menu together with DND.
    Please, press button second to In Office/Out of office.
  3. mthibodeau
    Jun 4, 2008
    7
    Thank you for your response.
    NOw is there a way to "stay" in Auto-Answer all the time... and save this configuration?
    I need to have the application configured in auto-answer mode all the time I start it... (ex: after a reboot with the application that start automatically.)
    Thank you
    Have a good day
    Marquis
  4. norekhov
    3CX Support
    Jan 31, 2014
    53
    Unfortunately no. This was a management decision not to restore auto answer
