Auto Answer
Discussion in '3CX Phone System - General' started by Anonymous, Dec 21, 2006.
  1. Anonymous
    Anonymous Guest
    Does 3CX support auto answer. Linksys SPA942 phones have a intercom auto answer function that sends out an invite with Answer-after=0 so the called extension will auto answer. This feature is quite common on analog PBX systems and is called Hands Free Intercom usually. Usually you have to dial something like *96xxx where xxx is the extension number.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    305
    Are you referring to auto answer by the phone/the extension? If yes then this is a SIP phone function - you would have to find a SIP phone that supports this. If its a popular feature they probably support it.
  3. Anonymous
    Anonymous Guest
    The Linksys SPA942 does support auto answer but the PBX must cooperate. When the phone makes an auto answer intercom call with "Answer-after=0" in the invite does the PBX pass that through to the called phone so it will auto answer? Alternativly the PBX could support a feature to do an auto answer by dialing a *xx feature code then the extension.
