Auto Attendant
Discussion in '3CX Phone System - General' started by msp, Aug 30, 2009.
  1. msp
    msp
    Apr 23, 2009
    19
    I recorded a voice prompt for the auto attendant feature using MS sound recorder and the format save was set to PCM, 8KHZ, 16 bit Mono.
    When the recording is played back through the auto attendant, the sound quality is poor (ie crackly) . If played back by using a mediplayer or other sound players, it has good clear sound quality. Does anyone know what is causing this issue in sound quality.
    regards kelvin
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    hello
    strange,
    maybe try to reinstall codec, like klite mega pack codec...
  3. Jetcityjules
    Feb 17, 2009
    6
    We are having the exact same issue. I re-installed the codecs and it didnt' make any difference. Any suggestions, we sould like we have speech impediments and that is not good for business.
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Please provide at least brief description of environment...
    1. hardware specification
    2. software specification
    3. typical load of your server
  5. msp
    msp
    Apr 23, 2009
    19
    After a lot of time in investigating this issue, We have discvered that it is due to the incompatibility of PC sound card codec and the ulaw codec in the IP phones. There is a very good example on the cisco website of this very same issue. The difference in the cisco example, it is demonstrating the effects of alaw to ulaw coding. what you hear in the example is what we are hearing in the auto attendant recording.
    I have found a work around for this problem.
    Remember that were these wav files are stored is different for each operating system type. The examples below are for MS XP Pro
    1. Record your DR announcement using the vmail greeting message recording option.
    2. Using file explorer go to C:documents and settings/all users/applications data/3cx/data/ivr/voicemail/data/"extension number" copy file savevmgreeting.wav file
    3. Paste it into C:documents and settings/all users/applications data/3cx/data/ivr/prompts,
    4. Rename the file to something like "DR announcement.wav"
    5. Open the 3cx management for the digital receptionist form and add the "DR announcement. wav" file into the DR.
    6 Go back to the vmail greeting recording option and re-record you greeting message.
    Now you will have a good quality DR recording.
  6. SY
    3CX Support
    Jan 26, 2007
    1,825
    Jetcityjules and Kelvin
    Are you using the same phone?
  7. Jetcityjules
    Feb 17, 2009
    6
    We don't have SIP phones. I'm using 3cx client, or my cell phone to dial in and listen. My clients have standard telephones. We are recording the vm via headsets and windows sound recorder.
    Hardware:
    OS: Windows 2003 Standard 32Bit
    Processor: 1.86GHz e6320
    Ram: 2 GB
    Drive 1: None
    Drive 2: 320GB
    I'm using OS of Windows 2003 Server. The load on our server is pretty light. We are a small company, have a dedicated hosted server, perhaps 6 users using it daily. We had the same issue when we had it on a dedicated phone server that ONLY had the 3cx on it. Our call volumn is not that high, perhaps 10 calls per hour.
  8. SY
    3CX Support
    Jan 26, 2007
    1,825
    So, it should be very easy to replicate the problem using following procedure (please correct me if I'm wrong)
    The procedure is:
    1. Install 3CX PBX(version?)
    2. Install 3CX VoIP phone(version?)
    3. dial special menu using 3CX VoIP phone and record personal prompt
    Is it enough to replicate problem?
    P.S. It would be good if Kelvin will provide further instructions.
