Auto Call Back when previously busy internal extension becomes available
Discussion in 'Ideas' started by smartsoft, Jun 7, 2016.
  1. smartsoft
    Jan 10, 2012
    11
    Have used may other PABX systems over the years. One of the features I miss the most is the auto call back when previously busy internal extension becomes available.
    When you are trying to speak to someone on an internal extension and they are on a call, this feature will automatically call you and connect the calls when they get off the phone.
    regards
    Tony
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    Some deskphones have this functionality already available on them as a built-in feature, so essentially you can set your extension to 'monitor' the other extension you are trying to dial.
