Auto callback Option
Discussion in '3CX Phone System - General' started by Jpaudio, Sep 18, 2014.
  1. Jpaudio
    Sep 18, 2014
    Hi everybody,
    I am currently trying to enable the auto callback function for my assistance center.
    On the call recording it gives me the option to press * to request a callback.
    When the extension starts to ring I pick it up, it should auto dial which it doesn't.
    I have set up a outbound rule, but it either drops out straight away or it goes to hold tone and doesn't call out.
    Any ideas? The outbound prefix matches both the queue and the outbound rule.
    Is there instructions anywhere on how to set this up?
    Julian
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    What are the outbound rule criterias set? only prefix or anything else?
  3. Jpaudio
    Sep 18, 2014
    Tried all diff prefix, any suggestions?
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    You should have a rule with prefix or number length criterias only, no criterias on extension/group of extension, is that the case?
