Auto Change Status When Idle
Discussion in 'Windows' started by tomnorton, Aug 24, 2017.
  1. tomnorton
    Feb 23, 2015
    21
    We have set our Windows Clients to 'Auto Change Status when Idle' after 5 mins.
    Is there a way it can auto change status when the PC is locked?
    Tom
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    245
    12
    Hello @tomnorton,
    Unfortunately, there is no such an option on the Windows client.
    Thank you
  3. tomnorton
    Feb 23, 2015
    21
    Thank you for the quick reply. I will log it as a feature request.
    I know this isn't for this particular forum, however there doesn't seem to be one for the WebClient I can see. The Auto Change Status when Idle option doesn't appear to work.
    Is there a prerequisite in order to get it to work? Using Chrome at the moment.
  4. Marios Neophytou
    Mar 1, 2016
    245
    12
    There is an issue at the moment on Auto Change Status using the WebClient.
    For now use the Windows client to make any changes on the Auto Change Status until the next release.
    Thank you
