Auto Dial after number typed in on SNOM 3xx
Discussion in 'Windows' started by ziptalk, Aug 13, 2009.
  1. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    We are used to dialling a number, and then the phone dials automatically.
    However on the 3CX/Snom 3xx, we have to press the 'tick' to confirm the number and then the call is placed.
    Does anyone know of a central configuration option or setting on the phone to change this behaviour so it dials when the number has been entered. I had quick look on the configuration on the Snom 300 and cannot see anything.
    Thanks, Lewis
  2. comresource
    comresource Member
    May 22, 2009
    303
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    On the Snom's there should be an autodial option in Advanced > Behaviour which will dial after a set amount of time if there are no more numbers entered.
  4. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Thank you that done the job nicely 8)
    That feature has been the only gripe by people in the office, the fact they had to press the 'tick'. You have made a lot of people happy.
  5. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Always glad to make people happy, let's hope they remember at Xmas :mrgreen:
  6. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Well the feature is offered conditional on a beer for lunch :roll:
    If they implement distributed ring groups I'll be good through to 2010 :lol:
