Auto Dialer using CFD
Discussion in 'Call Flow Designer' started by Maarten, Aug 18, 2017.
  1. Maarten
    Aug 9, 2017
    41
    Hey there!
    Would it be possible to setup some sort of auto dialer using the call flow designer?
    Could not find anything clear in the manuals about this.
    We really need this for our setup and as far as i could find out, 3CX doesn't have a Auto Dialer in there normal setup?
    Thanks in advance
    Maarten
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
  3. Maarten
    Aug 9, 2017
    41
    Hi @edossantos
    That's exactly what i was looking for! It won't matter what version you are running right? Windows/linux. The CFD is installed on your own device i assume and you create the dialer there?
  4. edossantos
    Jun 27, 2007
    1,080
    77
    The CFD is the development tool, and you need to install it in any Windows PC. It doesn't require any license, it's free to use.
    The apps created with the CFD can be deployed to both Windows and Linux. You need a PRO/ENT key to run these apps.
    Kind regards.
  5. Maarten
    Aug 9, 2017
    41
    Awesome! Thanks for the info! Much appreciated!
