auto forwarding calls between trunks
Discussion in '3CX Phone System - General' started by yelgadi, Jun 3, 2016.
  1. yelgadi
    May 13, 2016
    6
    Hello everyone,
    I have a question -might be a noob question- in my setup I need to connect 3cx to voipswitch and to goip
    what I am currently trying to achieve is that I want all of the calls coming from voipswitch to be auto forwarded to the GoIP box
    voipswitch is connected as a sip trunk (10000)
    goip is connected as a PSTN Trunk (90001 , 90002 , 90003 , 90004) 4 ports
    currently I can dial external numbers from extensions via GoIP
    but whenever I try to forward calls from voipswitch i get the following,
    03-Jun-2016 18:54:06.953 Leg L:14.1[Line:10000<<00114-faisal] is terminated: Cause: BYE from PBX
    03-Jun-2016 18:54:06.914 [CM503020]: Call(C:14): Normal call termination. Call originator: Line:10000<<00114-faisal. Reason: Not found
    03-Jun-2016 18:54:06.914 [CM503014]: Call(C:14): No known route from Line:10000<<00114-faisal to target: <sip:9@5.189.184.214:5060>
    03-Jun-2016 18:54:06.914 Call(C:14): from Line:10000<<00114-faisal to 9 doesn't match any outbound rule. No outbound rule could be selected.
    03-Jun-2016 18:54:06.914 [Flow] Target endpoint for 9 can not be built!
    03-Jun-2016 18:54:06.913 [CM505003]: Provider:[voipswitch] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [VoipSwitch 2.0] PBX contact: [sip:10000@yyy.yyy.yyy.yyy:5060]
    03-Jun-2016 18:54:06.911 [CM503001]: Call(C:14): Incoming call from Line:10000<<00114-faisal to <sip:9@yyy.yyy.yyy.yyy:5060>
    03-Jun-2016 18:54:06.911 Line limit check: Current # of calls for line Lc:10000(@voipswitch[<sip:10000@xxx.xxx.xxx.xxx:5060>]) is 1; limit is 4
    03-Jun-2016 18:54:06.911 NAT/ALG check:L:14.1[Line:10000<<00114-faisal] REQUEST 'INVITE' - basic check passed. No information for extended checks
    03-Jun-2016 18:54:06.903 [CM503012]: Inbound any hours rule (00218*) for 10000 forwards to DN:9
    I am trying to autoforward to external number 9 -as a test- and my outbound rules are setup to accept a prefix starting with 9
    but as I can understand from the log the 3cx is actually trying to call 9 instead of forwarding the whole number,
    can anyone assist?
    Thank you in advance guys,
    11,079
    324
    Direct trunk to trunk may not work. 3CX isn't really designed as a Tandem switch. Incoming calls are directed, in a number of ways, to an extension. With that in mind, an extension can then forward calls back out on a trunk. So... you will have to establish some extensions, send the incoming calls to them, and use the forwarding rules, of the extension to direct the calls back out again. This will also involve the use (creation) of the appropriate outbound rules.
    You may also want to investigate the use of a Bridge Trunk to connect to the other PBX, if you haven't already, there may be some advantages to using this connection method.
    This tells me that you haven't built an outbound rule, which may not be the only issue.
  3. yelgadi
    May 13, 2016
    6
    thanks for the reply,
    well for some reason bridging didnt work with voipswitch , the only option that worked was a sip trunk
    anyways Thank you for the info , I will try a little bit more , but i have a feeling that 3CX wont be the best option for my setup :(
  4. leejor
    11,079
    324
    Did you set the Bridge trunk on 3CX as the Master, and have the other PBX register to it as if 3CX were simply another VoIP provider?
    If you were able to use a VoIP trunk, then how did it register to the other PBX, as an extension on the switch? Or, does it allow a trunk to register to it?
    Users that have Bridge trunks to other 3CX installation, can dial over the trunks to an outside call at the far end. It all depends on exactly what you are trying to achieve. You may first need to review the outbound rules you created (or didn't) for the calls.
  5. yelgadi
    May 13, 2016
    6
    Hey Leejor,
    thanks for your reply,
    I tried to setup the remote voipswitch as a bridge as per your suggestion,
    and apparently there is an authentication issue -I am sure a 100% that credentials match-
    here is the log from a call:
    04-Jun-2016 21:32:12.261 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 164.132.81.230:443 tid=321219127999125118347771 Call-ID=JBi5xXcFia@164.132.81.230:
    INVITE sip:00218911184844@sip.elgadi.net:5060 SIP/2.0
    Via: SIP/2.0/UDP 164.132.81.230:443;branch=z9hG4bK321219127999125118347771
    Max-Forwards: 70
    Contact: <sip:164.132.81.230:443;transport=udp>
    To: <sip:00218911184844@sip.elgadi.net:5060>
    From: <sip:00274-belat@164.132.81.230:443>;tag=123219118347646
    Call-ID: JBi5xXcFia@164.132.81.230
    CSeq: 2 INVITE
    Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REGISTER, INFO, NOTIFY, MESSAGE, SUBSCRIBE, REFER, PUBLISH, UPDATE
    Content-Type: application/sdp
    Proxy-Authorization: DIGEST username="10000",realm="3CXPhoneSystem",nonce="414d535c0d63bdbc47:043664e12a1abc6393ce272ab1b36f6c",uri="sip:00218911184844@sip.elgadi.net:5060",response="afd7c833ec05e4b5b17a30f07feb97bf"
    User-Agent: VoipSwitch 2.0
    Content-Length: 282
    Remote-Party-ID: <sip:00274-belat@164.132.81.230:443>;privacy=off;screen=no
    v=0
    o=- 496502998 496502999 IN IP4 164.132.81.230
    s=VoipSIP
    c=IN IP4 164.132.81.230
    t=0 0
    m=audio 6764 RTP/AVP 18 0 8 101
    a=rtpmap:18 G729/8000/1
    a=fmtp:18 annexb=no
    a=rtpmap:0 PCMU/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-15
    a=sendrecv
    ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
  6. leejor
    11,079
    324
    Can you explain, in more detail, your setup (block diagram?), what digits you are sending (from where), and where you expect them to route. Types of trunks you've used, at each end, if the registration was successful...etc.
