Auto increment for new extension # / find open "slot"
Discussion in 'Ideas' started by the60, Jan 18, 2018.
Auto increment for new extension # / find open "slot" 5 5 3votes
5/5, 3 votes
  1. the60
    the60 New Member
    Oct 21, 2011
    117
    61
    Older versions would auto-assign a new extension with the next extension number, by adding 1 to the last extension number assigned, or, finding the first open "slot" in the extension list. This was a godsend..
    Please bring this back.
    Does anyone know how hard it is to find an available extension slot when there's 7 pages of extensions in production, with daily additions and removals by multiple admins?
    Am I missing something?
    (I also thought I saw this in another thread but cannot find it - Please cross-reference as needed)
    3CXDude likes this.
  2. the60
    the60 New Member
    Oct 21, 2011
    117
    61
    I now understand that extensions start at 000. I'll just import "dummy" extensions to avoid extensions starting with 0. Otherwise, system behaves as it used to.
