Auto intercom extensions on Yealink T46G in V15?
Discussion in '3CX Phone System - General' started by philodendrin, Feb 16, 2017.
  1. philodendrin
    Jun 16, 2010
    When we sell 3cx to customers coming off of a traditional analog or digital PBX (Avaya/NEC/etc) ...one of the biggest complaints we get is that they have to dial a * code to intercom employees. In their old systems they could just press the extension and have it automatically start the intercom to the extension they're dialing.
    Is there a way to automate this in 3CX to make it act like those older systems, such as a change to the template for the Yealinks?
  2. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    108
    42
    Go to settings > Dial codes and set a paging dial code (*99 is what we use but it doesn't matter what it is.). Make Custom Speed Dial buttons under BLF settings on an extension, *99101 will intercom 101, *99102 is 102, so on and so forth. On each extension that will use these you need to check Can Intercom under Rights in extension settings.
  3. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    47
    I would do it slightly different, Nortel style.
    Setup BLF as you would normally. - Pressing the blf would call the phone and you can use the key to transfer calls.
    Also setup a PREFIX key on your yealink with the value of your paging code and a label that makes sense to them (it would be Voicecall on a Nortel)
    So when they want to page an extension, they press the prefix button followed by the extensions BLF button.
