auto log into vocie mail
Discussion in '3CX Phone System - General' started by aftermarket, Jun 10, 2009.
  1. aftermarket
    May 13, 2009
    84
    hi
    running the cisco 7940 phones and now when i press the messages button it connects to vocie mail on number 121. every time it does this it asks me input my pin is there anyway to get the phone to do this for me?
    thanks
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    5
  3. aftermarket
    May 13, 2009
    84
    hi thanks for that i have now upgraded but how do you enable auto logging in of the voice mail?
  4. leejor
    10,360
    226
    Is there not an option that has to be set for each extension that doesn't want to have to input a PIN?
  5. mbaltus
    Dec 12, 2008
    66
    In the 3CX Management site go to Settings -> Advanced and select the Custom Parameters Tab
    Edit the VMPINREQUIRED option and set it to 0. After this the pin code is no longer required to be entered (note, in my case it was the top-most option mentioned).
  6. leejor
    10,360
    226
    I would have thought that this would have been a per-extension option as some users may wish to continue to use a PIN.
  7. mbaltus
    Dec 12, 2008
    66
    We hardly use the voicemail option, so a general setting would be just fine. But I can imagine that this could be set on a per extension basis. Although some companies may want to enforce using the pin from a security point of view.
  8. leejor
    10,360
    226
    I agree that the default (just as it is) should be the requirement to enter your PIN. There are some extensions, softphones, executives with locked offices, a common phone serving more than one person, etc., where the individual doesn't feel that a PIN is necessary. On those extensions only, the ones that request it,you should have the ability to turn it off
