Auto Provision for Yealink T21P model
Discussion in '3CX Phone System - General' started by fungwan23, Oct 26, 2016.
  1. fungwan23
    Aug 4, 2016
    7
    I would like have some advise that I unable to perform IP phone auto provision from 3cx server (version 14). Each time, I need to manual type-in data into the phone. Anyone can advise what should I check & do?
  2. AlexanderHanna
    Oct 2, 2015
    79
    10
    When you connect the Yealink phone, due to the PnP, you should see the phone details in bold in the Phones tab in 3CX. Are you not seeing the phone listed there?
    Alexander
  3. fungwan23
    Aug 4, 2016
    7
    Yes, I can see the phone list in the 3CX. When click and browse into the phone, I set provision URL address and try provision from 3cx system to phone, it nothing happen. The phone seen won't get any update data from 3cx system.
  4. AlexanderHanna
    Oct 2, 2015
    79
    10
    If you are seeing the phone in 3CX PHONES tab, then select the phone and then select "Assign To Extension", then select the extension from the list you want to assign to the phone and then save. After a few moments, the phone should be assigned to the extension.
    Alexander
  5. fungwan23
    Aug 4, 2016
    7
    I see. What if I can't detect or see the phone list in 3cx?
  6. AlexanderHanna
    Oct 2, 2015
    79
    10
    Well that is a different story and was the reason why I asked if you were able to see it in the list. While you don't need DHCP, you might want to check this to ensure if you have option 66 that it is pointing to the correct address of 3CX. I seen cases where this was pointing somewhere other that the 3CX location and caused issues. Also review your DNS to ensure it is correct.
    Alexander
  7. fungwan23
    Aug 4, 2016
    7
    I see. One more thing, when I run the firewall checker, it prompt some error:-
    resolving 'stun.3cx.com'... done
    resolving 'stun2.3cx.com'... done
    resolving 'stun3.3cx.com'... done
    testing 3CX SIP Server... failed (How to resolve?)
    stopping service... done
    testing port 5060... failed
    testing port 5060... full cone test failed
    starting service... done
    What is that mean?
