Auto provision url and iis
Discussion in '3CX Phone System - General' started by flexmcpee, Oct 19, 2010.
  1. flexmcpee
    Oct 19, 2010
    7
    I am trying to Auto provision 2 phones the Aastra 53i (Latest Firmware) and Snom 300 (latest Firmware)
    I have setup 3cx on a windows server 2008r2 box, installed the dot net framwork feature on the server as required. I have also disabled the ie esc (internet explorer enchanced security configuration) as required.
    I can create the extensions in 3cx by specifying the Mac of the Phone, the model and the host adapter (nic) I give it all the neccasry details for the extension click Apply and ok as per the guide to auto provision the 2 models in question.
    I have 1 created 2 dhcp option 66 for each phone to use the below urls
    Snom 300 http://192.168.0.9/management/provisioning/cfg{mac}
    Aastra 53i http://192.168.0.9/management/provisioning/
    I have also tried to manually point the phones within the phone settings to the above urls still to no avail.
    I can manually provision both phones successfully however I would like to get the autoprovision within 3cx to work without having to touch the phones. My question is this the urls above how can I first check they exist and the config files written by the 3cx server are actually there. Where do I look for this area/directorys on the 3cx server? Is it a directory somewhere on the c:drive or is it a site created in IIS as I cant see either of those locations. The IP above in the url is the 3cx server.
    Sorry I am new to this and just need to know that first the location exists and second where can I see the conifg files that are ready to be picked up by the phones on bootup?
    Any suggestions would be great.
    Alex
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi Alex,
    if you have managed to manually provison them then the files are there! But just for completness sake you can see if the file exists by doing http://192.168.0.9/management/provisioning/mac address of your phone.xml. It seems that the option 66 is not set up correctly or for some reason the phones are not picking it up.
  3. flexmcpee
    Oct 19, 2010
    7
    Hi Mark,
    Thats great thanks for the fast reply.
    Please see the attached screen shot that i recieve when I put in the browser address http://192.168.0.9/management/provisioning/00085d101580.xml. I have tried the Mac address of 3 phones and they give the same thing.
    Thanks again for your fast response I am impressed :)
    Alex
  4. flexmcpee
    Oct 19, 2010
    7
    I assume no one knows the answer to the above?
