Auto Switch presence not working in V15
Discussion in '3CX Phone System - General' started by mnadvornik, Sep 30, 2016.
  1. mnadvornik
    Sep 30, 2016
    8
    Hello everyone,
    since we updated to V15 the "Automatically switch status during office hours" function is not working for our extensions. It does not matter whether we set it to global office hours or define some for the extension. The presence always stays the same as if the setting was not activated.
    I have confirmed the server time to be correct but even within 24 hours there is no time the presence is automatically switched.
    I would appreciate to find a quick solution as we have been using this feature heavily in V14 (100+ extensions) and our employees are already complaining.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Hi - we are going to check this and get back to you - thanks for reporting.
  3. dkintana
    Dec 21, 2015
    9
    I'm having the same issue in my updated v15. In v12.5 it worked perfectly. I have two installations pending to be updated because this issue.
    Regards,
  4. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    We have a fix for this - It will be available in SP2 coming in the next 1-2 weeks.
    We can also provide a patch.. Would you be interested?
  5. dkintana
    Dec 21, 2015
    9
    Thank you very much, Nickybrg.
    I think I can wait to SP2 if it will take only 1 or 2 weeks.
    In the meantime, will test thoroughly this version.
    Best regards,
  6. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Confirmed.
    No we are in test phase and 1-2 weeks time we will release SP2 and this problem is guaranteed to be fixed. Thanks for your patience.
    Anyone else that wants this fix let me know. (PM)
  7. mnadvornik
    Sep 30, 2016
    8
    Hi nickybrg, we would be very interested in getting a patch!
  8. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    We are gonna make an update this week..
  9. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    SP2 is out, keep us informed regarding this.
  10. infrastructure1
    Jan 6, 2015
    Has this been fixed? we are on the latest version and are still having issues with the auto switch.
  11. global43
    Jul 17, 2012
    I also need this function for my client, already have a prediction for this fix?
  12. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,479
    466
    Hi there,
    Please note that the fix for this was included in SP2 as mentioned, and we had no issues since then.
    Please make sure that your settings are correct and that you have updated to SP2.
