Solved Auto Switch
Discussion in '3CX Phone System - General' started by steve matten, Apr 6, 2017.
  1. steve matten
    Dec 19, 2016
    17
    It seems that I can configure an extension with available office hours but once that is done I cannot change it. If I select configure after I have previously set hours then the Delete button and the OK button are disabled. Is there a secret way of modifying the Office Hours setting for the Auto Switch?
    Thanks.
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    385
    52
    Are you using a non-supported browser? When in doubt try with Chrome.
  3. steve matten
    Dec 19, 2016
    17
    Using Chrome.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,970
    183
    clear your cache.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @steve matten
    This is a bit confusing but once you configure an office hour and need to change it, you need to click on the entry that is already configure and delete it.
    Then you can configure a new set of hours. The configure button lets you configure an additional set of hours but they shouldn't overlap with the already configured set. If they overlap then the buttons will be greyed out.
  6. steve matten
    Dec 19, 2016
    17
    That worked. In the extension, call forwarding section, Auto-Switch I clicked configure. If the hours are set there will be two hyperlinks, one for the hours and one for configure. I clicked on the set hours and deleted, that removed them, then I could configure them again.
    Thanks.
