Auto Updating Corporate Phonebook
Discussion in '3CX Phone System - General' started by jurickk, Jan 14, 2010.
  1. jurickk
    Dec 21, 2009
    We constantly add new contacts to our database, which is a separate entity from the 3cx phonebook, I have the ability to dump all of the contacts from our database into excel, then save it as a csv file, and upload it to the corporate phonebook, I'm trying to make this more hands-off so that I can have our database do a nightly dump, then 3cx will grab that dump and upload it automatically. I have not been able to find any options to auto update the phone book, nor have I found it's location after uploading. If anyone knows where either of these exist it will put me on the right track really quick. Thanks
  2. unoa
    Oct 14, 2009
    22
    Same here, anyone has any idea how to get this up and running? Can't seem to find a way to automagicly update the company phonebook like jurickk states ..
