Automated calls
Discussion in 'CRM / Helpdesk / App Integration' started by cyberspot, May 7, 2010.
  1. cyberspot
    May 12, 2008
    87
    Can i make a project with vad that can make automated calls to clients and play a message to them.
    The list for the clients will ne in a access database.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    The VAD can only handle inbound calls. To make outbound calls you can use the HTTP API (http://www.3cx.com/blog/docs/3cx-http-api/). You can create a process which uses that API to create outbound calls and transfer them to a VAD callflow. Then, you can use the VAD to graphically define the callflow (play audio prompts, request user input, etc.).
