Solved Automatic call log deletion?
Discussion in '3CX Phone System - General' started by Eli55, Apr 28, 2017.
  1. Eli55
    Jan 2, 2017
    20
    Event Notification Manager ID: 10025 Old call log files were deleted to conserve disk space.
    How can I disable this???
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Eli55,
    The notification you saw is from the Event Log in the Dashboard. The actual call logs were not deleted, only the event logs. You cannot disable the feature, but you can set up what is shown, and the time that the logs are kept.
    Hope this helps.
    #2 Panayiotis_3CX, May 3, 2017
    Eli55 likes this.
  3. Eli55
    Jan 2, 2017
    20
    Thank you, that explains it!
  4. Alessandro Ranieri
    Mar 29, 2017
    13
    I have a stupid question...how can you put the "solved green mark" in the title of the post?
    A.
  5. agp
    agp 3CX Team
    Aug 19, 2015
    154
    22
    Hi Allesandro,
    Only staff members can mark a topic as solved.
  6. Alessandro Ranieri
    Mar 29, 2017
    13
    Thank you very much!
    Have a nice day
    A.
