Automatic recall
Discussion in 'Ideas' started by digito, Oct 11, 2016.
Automatic recall 5 5 2votes
5/5, 2 votes
  1. digito
    Mar 2, 2009
    6
    When I transfer a call to an internal extension that is occupied it would be great to have a function that permit to automatically transfer the call when the internal extension will be free.
  2. Phone systems NZ
    Feb 15, 2017
    53
    16
    I have used this feature on other systems and it is very handy, would be nice to see it added to 3CX
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    It is possible to build this feature using the Call Flow Designer and the 3CX Call Control API. If you really need it now.
