Automatic Routing Between Bridged Systems
Discussion in '3CX Phone System - General' started by Bamele, Mar 21, 2015.
  1. Bamele
    Mar 21, 2015
    Hi I have a question about 2 3CX Phone Systems bridged together.
    I am thinking of implementing 3CX systems in both our offices. I would like to know though if I bridge these offices and assign different prefix numbers to dial between extensions of these offices, will I be able to assign rules to an extension in office A to route to an extension in office B say when the office A is closed and someone from outside rings a number that is directed to an extension in office A.
    In other words route a call to office B when office A is closed and a out of office rule is set up to forward the calls to office B.
    Will I be able to see extension of Office B in the admin console of Office A when setting up a rule for the extension in office A?
    Thanks in advance.
    Bamele
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,560
    301
    Just pretend it is an "External Number".
    So if in Office A you need to reach Office B, and it's prefix is 22 and want to forward calls to ext 300 - put 22300 in the External Call field. It will go thru the Outbound Rules and find the right one.
  3. craigreilly
    Feb 1, 2012
    3,560
    301
    <-- if you have a PRO license only.
  4. Bamele
    Mar 21, 2015
    Thanks guys, these are all the answers I was looking for.
    Time to deploy :)
  5. netswork
    netswork Active Member
    Mar 11, 2011
    577
    If your install is going to be small, limited to these two sites, you dont have to use prefixes...just plan it out. I have a customer with 9 locations all bridged and we dont use any prefixes. So they just dial extension to extension like normal.
    11xx branch 1
    12xx branch 2
    13xx branch 3
    ect.
    I make sure to not overlap system extensions for things like trunks, ring groups, IVR's and conferencing. It makes it easier for the user to just dial the branches 4 digit extension.
