Automatic Weekly Reboots of Phones
Discussion in '3CX Phone System - General' started by Mark Stevens, Oct 11, 2017.
  1. Mark Stevens
    Sep 13, 2017
    5
    All
    Is it possible to schedule a reboot of certain phones within the 3CX system?
    Regards
    Mark.
    11,285
    360
    You may have to resort to a digital timer if the set is AC powered.
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,325
    221
    If phones are connect via Poe switch, can you schedule reboots of the switch
  4. TWU
    TWU
    Jan 12, 2016
    18
    Use free software curl (curl.haxx.se), and use task planer to schedule job:
    curl.exe --data reboot=Reboot --user %USERNAME%:%PASSWORD% %SNOMIPADDRESS%/advanced_update.htm --connect-timeout 10
