Automatically change an extensions status based on time.
Discussion in '3CX Phone System - General' started by mitchell, Apr 7, 2018.
Tags:
  1. mitchell
    Apr 6, 2009
    5
    Is there an option somewhere that I can use to change an extensions status to away? I know there is one to change to available but I can't find one to change it back.
  2. pmterp
    Jun 13, 2017
    42
    6
    You can use the auto switch function under the extension's forwarding tab to set a schedule. During defined Office Hours the phone will be set to Available. When the Office Hours end, it will be set to Do Not Disturb (not "Away" though).
    Hope that helps.
  3. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
