Automatically configuration of 3CX
Discussion in '3CX Phone System - General' started by sofaf, Jan 16, 2007.
  1. sofaf
    Jan 16, 2007
    Hi all,
    Maybe someone know is it possible to configure 3CX PBX automatically (I mean the adding extensions, configure rules etc.)?
    thanks in advance,
    Sofya
  2. rascott757
    Jan 13, 2007
    9
    Automatic configuration
    The manual does mention importing extensions from a spreadsheet/csv file. In terms of other configurations, I'm not sure what you mean. The system is very easy to configure as is.
  3. Watashi_FR
    Dec 5, 2006
    63
    The configuration is stored in the Postgres-database that comes with the system. If you examine the configuration backup, you'll notice that it's an XML dump of that database inside a zip file. Editing this XML file is possible, but the results are questionable to say the least (since the internal config format is not documented). That said, configuring 3CX through the web interface is easy, so it would seem futile to invest time in an automatic configuration (and then there's no way to automatically configure your own sip accounts anyway).
  4. sofaf
    Jan 16, 2007
    Hi all, thanks for the answers.
    I would like to use the 3CX in automatic tests, so I need to install and configure the PBX automatically.
