Automatically configure Yealink RPS server in hosted edition
Discussion in 'Ideas' started by gotvoip, Feb 16, 2016.
  1. gotvoip
    Feb 10, 2016
    7
    Currently when we want to provision a Yealink for PnP with 3cx we have to login to the RPS server and put in the PnP string that is generated by 3cx. Then we have to go into 3cx and add the mac address for the phone. It would be ideal if 3cx can automatically provision the RPS server by logging in via its API and create the new server since it knows what it is and then add the device with that mac address. It would save some time and ensure there were no typos which would also help speed up the deployment in a hosted setting. Thanks,
